bolts question
Old Aug 11, 2008 | 01:13 AM
daniel6718's Avatar
Default bolts question
on a ls1 are the
oil pump
oil pan (except rears)
front/rear cover
cam gear
vally cover
timing chain tensioner
cam retainer
bolts all the same? i know the threads are but the leingth and everything the same?
and on the puckup tube for the oil pump theres 2 holes in the pump for bolts but my pickup only has 1? and i think its missing an o ring on it? is that a gm piece? got a part number?
Old Aug 11, 2008 | 02:17 AM
Halloran's Avatar
Not sure about the sizes... I can tell you that my pickup tube also only has one bolt that connects to the pump (although the pump allows for two bolts) so don't worry about it.
Old Aug 11, 2008 | 06:05 PM
Omega's Avatar
There is only 1 bolt hole on the pump, so don't worry about it. The part number for the pick-up gasket is: 12557752 on the ws6store.com site.
Old Aug 11, 2008 | 06:19 PM
Sammyboy's Avatar
no not all the bolts are the same length. The oil pan consist of 3 separate size bolts....etc.
Old Aug 12, 2008 | 11:44 PM
daniel6718's Avatar
which ones are differant leingths? i thougght that pan wazs all the same except the rear 2?
