ls6 cam and heads worth the effort on 2k ss ls1?
i have 02 ls6 long block, wondering if its worth the effort to swap heds and cam onto my 2k SS ls1, what are the cam specs , comparitively? seems like alot of work. I heard there's special tools to line up front cover or some thing else, i dunno....tia...
I'd swap the LS6 long block into your car.
Would be even more fun if you pull the heads off of the LS6 and get them ported before doing the swap. You've got a golden chance to take the LS6 engine go thru it or have a pro go thru it and build a killer engine then swap it in.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
