took off heads, found gunk on 1 piston?
Old Aug 15, 2008 | 01:09 AM
themack56's Avatar
Exclamation took off heads, found gunk on 1 piston?
what does it mean and what can i clean it with
Old Aug 15, 2008 | 05:44 AM
9secondsflat's Avatar
i have never heard of that technical term "gunk" but if you have "gunk" obviously you need use "gunk remover"
randy from doug rippie (drm) says they use something similar to a non soapy nylon type of brillo pad that is approved by the fda for cleaning the tops of pistons. you may want to give him a call to find out where you can pick one up
Old Aug 15, 2008 | 08:32 AM
5.3LJimmy's Avatar
Approved by the Food and Drug Administration for cleaning pistons? You can scrape the bulk of it off with a gasket scraper then clean with some carb cleaner and a towel.
Old Aug 15, 2008 | 08:34 AM
andrew69_04's Avatar
im sure billy mays has some product that will make it like new....
Old Aug 15, 2008 | 08:55 AM
HaulinHawk's Avatar
LOL
Old Aug 15, 2008 | 09:20 AM
themack56's Avatar
not gunk gunk. but some hard black stuff on there
Old Aug 15, 2008 | 10:07 AM
Nabdrill's Avatar
I've cleaned them up with the soft-fiber pads on an air grinder. It cleans them good and doesn't scar the piston.
In the future, spray alot of nitrous and you won't have any gunk!
Old Aug 16, 2008 | 03:23 AM
LilJayV10's Avatar
LOL. That's awesome. F seafoam!
Old Aug 16, 2008 | 07:46 AM
LS1C5Vette's Avatar
I think you mean Carbon
Old Aug 16, 2008 | 09:27 AM
lj04's Avatar
that sounds about right
Old Aug 16, 2008 | 08:07 PM
massls1guy's Avatar
Interesting that you only had carbon on #1, I had it on all of them. Maybe you had a bad seal on the valve(s) for #1.
Old Aug 16, 2008 | 08:22 PM
Pwebbz28's Avatar
Gasket remover works WONDERS on carbon build up. Spray it on and let it sit for about 5 minutes and it will just wipe off. Spray the cylinder with WD40 after you're done.
Old Aug 16, 2008 | 09:23 PM
JFM-jr's Avatar
Carb cleaner a rag and some elbow grease did me wonders on mine.
Old Aug 16, 2008 | 10:16 PM
2002_Z28_Six_Speed's Avatar
Are you talking about the one where someone could key your piston and it will still take the scratch out? I heard hot dipping in oxyclean makes cast alum look like day one.
Old Aug 16, 2008 | 10:21 PM
firefighter813x's Avatar
he's my hero!
Old Aug 18, 2008 | 05:19 PM
Dex's Avatar
Dex
Old Aug 18, 2008 | 09:17 PM
smokintiresz28's Avatar
guess we should all run shell gas... HA HA
Old Aug 18, 2008 | 09:28 PM
hirdlej's Avatar
+2000
Did this on my LQ4 and had all 8 cleaned to a mirror finish in 15 minutes.
Old Aug 18, 2008 | 09:38 PM
THENASCAR's Avatar
or you could suck a little atf through a small vaccum hose, smokes like a MF but cleans amazingly
Old Aug 18, 2008 | 10:17 PM
1Bad00SS's Avatar
How is everyone missing the point of this thread? Guy here wants to know why only 1 is carbon'd up, not how to clean just 1!
As said above, likely bad seal.
