Quieting the Valvetrain after big cams
Im willing to believe that a different oil makes a diffrerence though. A long time ago one of the vendors I didnt have such good luck with told me to run a slightly heavier weight oil to quiet the valvetrain alot. I never tried it.
Im going to call a few of the better vendors around and see if I can get their opinion on this as well. I'd like to have some kind of concensus on this on the board rather than a big mystery hanging out there.
chris
I don't have air tubes, so it is not that. I know my forged pistons slap like anything when cold, but that goes away when warmed up.
Sounds kinda like a truck now according to my wife
over time it has come down a little (or either I have not noticed it as much).....but its still LOUD...
parts:
- TR224/224 112LSA
- stock lifters
- 7.400" chrome molly pushrods
- stock rockers
- 2.08"/1.60" valves
- Comp 987 duel springs (inner, outer, dampener)
- rollermaster double roller chain
a friend of mine has stage 2 heads (smaller valves) but with a TR230/224 111LSA cam and his valvetrain is much quieter than mine.....so this leads me to believe that my noise is comming from the larger valves and their seats.....
I have considered doing rockers to try and get rid of the noise but I just don't see it being worth $500+.....
I wonder what length pushrods I have. I know my heads have been milled *alot* since I had to alter the LS6 intake to fit between the heads.
chris
fuel injectors are noisy
air check valves are noisy
valve train is noisy
I am not blaiming the rocker for the HP loss still tring to find that one. Think its plugs and low gas issue.
I think valvetrain chatter can be from any of the following:
-Fast ramp cams
-Minimal lifter preload, like zero lash
-Increased noise going from stock manifolds which are doublewalled to single wall headers
My S1 was a ton louder than it's predecessor Lunati 242/242//114. Same preload.
I put Y/T's on my current engine, but I have like 10 minutes of run time on the motor.
From the Vendors:
Aftermarket Lifters make a big difference since they like so much less preload.
2.08 valves are noisier than 2.02, etc.
Fast ramp rates make a big difference, but there is no other way to great power.
While noone on the vendor side has said they htink YTs will quiet the valvetrain, they have sene most get louder with Cranes, etc.
So far, I have almost every possible thing going against me... Large valves (2.08), Comp R lifters, stiff springs, headers, and a mean ramp rate on the MTI X1.
urp.
chris
jay
Terra yellows
Crane R lifters
Lunati double springs, Ti retainiers
LS6 valves
Hardened pushrods
220/220, 564/564, 112
Rollmaster double chain
1) Valve size seemed to matter NONE. I went from stock headed to ARE 2.08 valve headed, and valvetrain noise increased zero on the given cam. I then went to a 2.02 valve and and more aggressive ramp rate, the noise increased a lot. Valve size seems to play no part in this, or at best, a ver miniscule part.
2) LIFT does not make a cam noisy! Its ramp rate. You could have a 0.500" lift cam that'd be noisy as hell, and a .580" lift cam that is quiet.
3) Lifter preload probably does matter a little (or a lot if you are running none), but after throwing in 3 different sets of pushrods, the sound was the exact same on all 3. 0.120" preload, 0.70" preload, 0.20" preload, it didn't matter. The stock lifters quite simply didn't care. I tried the same with CompR lifters after a head swap, same deal. Car ran fine either way, even dynoed the same!
4) YT rockers will probably quiet it down by maybe 5%-15%. Its hard for me to say since I've never installed a set on my car, but the set I did install still sounded noisy to me. The owner of the car however said it was a tad quieter than before, so I'd imagine its worth something there.
5) Headers don't seem to affect valvetrain noise. They do add lots of engine bay noise and noises from under the car from exhaust pulses, but the valvetrain noise itself was loud when I had stock manifolds, and its loud when I had FLP's. Zero perceived change there.
6) Visceral, your car sounded fine to me for the combo you have. Your valves/headers/preload IMO has nothing to do with it. Throw a softer lobed cam in and you're set. My 230/230 .566/.566 112lsa cam was quiet as can be because it didn't use the fancy high ramp rate lobes that are so popular now.
How messed up is that?
chris
Dynomat your engine bay.
I worked around from the valley cover (front part exposed by intake), up the heads, to the valve covers, and then finally to the header....
To me it HAS to be the valves snapping shut hard (fast ramp rate, stiff springs, and large valves on hard seats).....
precedure:
1) At the lifter valley it was "fairly" quiet (mostly head what I take to be chain noise from the double roller)....
2) when I move to the head (started at the bottom), I heard the "crack" of the cylinders firing but in the "background" (very light over the other noise) I heard a "ting ting ting" sound.....as I moved up the head (closer to the valve cover) it died down.....as if I got farther away from it.....
3) I moved to the valve covers and NOTHING....just "typical" internal combustions noise.....nothing metallic or ticking of any kind...
4) finally I jumped down the headers (hooker LTs) and sure enough, along with that BEAUTIFULE LS1 exhaust note (a little loud though)
.....TING TING TING.....sped up as I increased RPM (slowly rolled throttle).....sounds exactly like striking a bell....
I remember before I installed the valves (first came in the mail) as I was getting them out of the box I lightly struck them together and they rang like bells....really good tone I might add.......
How is the documention on the Viseral long-block swap going; many here are anxious to see the results?
I have Lunati double springs, Comp R lifters, LS6 hollow valves, Terra Yella's, and a smallish cam 220/220, 564/564, 112.
My valve train noise is about the same as a stock car...very quiet...
You can imagine that Jon will post something right away when he gets it done
chris
Anyway, I'd say its at least 2 weeks off...I've got more important writeups to do at the moment. I do have loads of pics tho and the whole thing is on my to-do list.
