Broken timing chain question.
Old Aug 31, 2003 | 01:39 PM
Wicked ls 1's Avatar
Default Broken timing chain question.
Well racing at US41 last night at the 1000 ft mark motor just quit. Pulled the front end apart[ gotta get puller for pulley] the chain is broke there was no noise and when I crank it over theres no noise what are the chances I bent the valves? and whats the easiest way to tell if the valves are bent?
Old Aug 31, 2003 | 01:47 PM
Cal's Avatar
Cal
Default Re: Broken timing chain question.
If you broke the timing chain, it's 100% that there are bent valves and damaged pistons. If the cam stops but the crank continues to spin, some of the cylinders will be left with their valves open and the pistons will hit them.
Old Aug 31, 2003 | 01:57 PM
MyLS1Hauls's Avatar
Yup, you've definitely got some damage. Especially since the motor was running high rpm when the chain went. Hopefully it will only be valves and no damaged pistons. I've even heard of one case where some connecting rods got bent. Dont ask me how. What cam were you running? What pulley did you have on the car? I always hate these posts as I'm pressing my luck with the stock chain. Good luck to ya. Also, dont try to turn the motor over anymore...you may just end up causing more damage.
Old Aug 31, 2003 | 02:16 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Mike, I broke a timing chain once, and I bent all the intake valves, what happened? You have a cam in the car right?
I have the pulley removal tools if you want to grab them.
reason Im asking is Ive had 2 cars in the past that I broke timing belts on and never hurt anything else.
Old Aug 31, 2003 | 02:23 PM
Im gonna see if auto zone rents them if not Ill let you know I have a rollmaster single billet chain on there the car just shut off at the 1000ft the cam is a tr224 on a 114 Im gonna be out of work for atleast 4 months starting in january for a kidney transplant dont need this right now.
Old Aug 31, 2003 | 04:28 PM
MyLS1Hauls's Avatar
These were overhead cam motors and lots of those are non-interference motors. The LS1 is an interference style unfortunately. Dang, you broke a Rollmaster chain? You didnt happen to have an SLP pulley on there did you? How many miles on your setup?
Old Aug 31, 2003 | 06:13 PM
Tin Indian's Avatar
Well, I have a single Rollmaster on mine too. Jeeze... Now you have me worried!
Old Aug 31, 2003 | 06:43 PM
Well its confirmed chain did snap, pulled the r/side valve cover loosened up the rockers and atleast the #2 cylinder is open 3500 miles on this chain and I dyno only at 377 rwhp so what gives with this chain it shouldnt break that easy
Old Aug 31, 2003 | 06:47 PM
Dope's Avatar
I don't have much to say, but this is a good reminder to go with double chains (and double springs). A bit of redundancy is worth it!
Dope
Old Aug 31, 2003 | 06:54 PM
Dope
Tell me about it the shop recommended this chain though so who can recommend a easy to install double roller dont want this to happen again.
Old Aug 31, 2003 | 09:33 PM
Jorday's Avatar
Yah, I am always wondering how bad I am gambling by using the stock chain. Strange you broke that one.
Jordan
Old Aug 31, 2003 | 09:45 PM
99 Black Bird T/A's Avatar
Jorday, all I can say is I lost sleep at night thinking about having the stock chain so 2x Rollmaster went on when it was heads and cam time.
I have the double and I'm worried again
Old Aug 31, 2003 | 09:47 PM
Mike K.'s Avatar
What about the JWIS single chain? It is supposed to pretty strong isnt it?
Old Aug 31, 2003 | 09:49 PM
Tin Indian's Avatar
They always say; "The Rollmaster timing set comes with the Iwis Ketten chain. The best chain available"
Supposidly much better quality than the GM spec'd Renold chain.
So, what the deal with this superior chain breaking?
Old Aug 31, 2003 | 09:54 PM
Tin Indian's Avatar
The Rollmaster timing set is made up with timing gears produced by ROMAC/Rollmaster in Australia. The chain is made by Iwis Ketten (Jwis) in Germany. Rollmaster does not produce chain.
BTW, the stock GM chain is produced in England by Renold.
Old Aug 31, 2003 | 10:14 PM
1999_SS_M6's Avatar
does anyone know of an instance where the stock chain has broken? I don't recall one off-hand...
Old Aug 31, 2003 | 11:09 PM
Bill00Formula's Avatar
When I did heads/cam om my '00 formula I didn't replace the stock timing chain. It broke after about a year. I haven't assessed the damage yet. should know in 4-6 weeks.
I was thinking about going with the rollmaster.
Old Aug 31, 2003 | 11:50 PM
JF WS6's Avatar
Wow, I'm certainly suprised to read that you broke a Rollmaster chain...... but this got me thinking (and I'm sure this has been discussed at some point before) but why is there no gear drive timing set for the LS1 from like Pete Jackson or something? I would think a billet gear drive timing set would be more reliable and less likely to break than a timing chain, but what do I know.
Anyhow, I'm glad I got the double roller...
Old Sep 1, 2003 | 12:17 AM
pdd's Avatar
pdd
o man just did my cam a tr224 and kept the stock chain. i hate toripe the car apart again
