Texas Speed trys a texas quick one on me?
This is a quote directly from Tony @ AFR.
"the only way to know if you have our standard 8017 spring or our upgrade 8019 spring is to actually physically have the spring off the head. If the inner coil is the same length or just a little shorter than the outer coil you know its our standard spring. If the inner coil is about .200 taller than the outer spring you know its our upgrade version and the one you really need for that set-up."
Hope this helps!
Tony
The head is milled so I know these were setup for me but these seem to be the standard springs. Am I missing something here?
They knew I was an LS1 noob... was this by accident? I went with TSP for their great reputation on this site.Thanks for confirming the springs. I was pretty sure I didn't have the right springs, but figured I better confirm with you all before I called them Monday morning. BTW, I just found this out today so I haven't had a chance to talk with them. I'm sure they will make it right.
he said he called them and talked to them i really do not think he needs their number again. Read his post next time. But they are closed today and tomorrow so he is posting here looking for help. Nothing wrong with that. It is not like he said texas speed tried to screw him on purpose.
