timing chain
Check out this post by "WickedLS1" if you have any doubts:Broke New Timing Chain!!!
not even 3500 miles and guess what it fricken broke
fluke maybe but guess what Im pulling it apart now bent a few valves Im getting a double this time. Trending Topics
With just under 28k on it, seen no reason.
For those still running a stock shain, why would you spend good money on a cam or heads/cam and not replace an $80 part. If you look at the stock setup against an aftermarket set like the RollMaster, the difference is amazing.
1) percentage of people that have had to redo the pumps, faulty porting etc..
2) percentage of people that have had to pull it all back apart for a damn little o-ring, **** porr design on that one
3) there is no significant increase in pressure or volume unless the stock pump is out of tolerance.
Matter of fact my friend had a H/C plus new chain and pump installed buot same time as i did mine. he ran his car less than 1,000 miles since (i have over 4,000) and his oil pump is not flowing oil anymore, used to be up at 60+psi, not anymore. Too much already.
But agreed to lose the chain on our valvetrain will suck, so new one will go in shortly. What sup with the doubles and clearing the ASP pulleys? Is this fixed or not? Have a newer (SFI spec'd) pulley will the double clear or do i need to "custom machine"?
http://www.sdpc2000.com/cart.asp?act...amp;catid=2267
SDCS1140 LS1/6 Double Row HD Timing Set $65.60
SDCS1160 LS1/6 Heat Treated w/ Torrington Bearing Timing Set $84.25
The heat-treated set includes a Torrington bearing on the cam gear and the necessary oil pump spacers and mounting hardware.
Makin’ a cam change? Then it is time to update that stock timing set with a heavy-duty 3/8-pitch double width roller timing set that uses the finest German made chain in the world! We use these same chains on our 1000hp big block Chevrolets and we have not had one failure. Precision-machined billet steel gears insure strength and perfect cam timing. The unique crank gear has 9-different keyways to allow for simple adjustments of cam timing.
