stock main bolts question (pics)
Old Aug 21, 2008 | 12:56 PM
DRCE's Avatar
I've used the set that came in the engine to measure clearances and then toss those and put in new with GM EOS lube on the threads. Can't beat it. The clamp load of the two studs new v.s. a previously used bolt is marginal at best.
Old Aug 21, 2008 | 01:03 PM
youguessit's Avatar
Originally Posted by NavyBlue99SS
Dont be cheap thats how you run into trouble and learn lessons. Look at it this way. Your already in there and your questioning if you should or not correct? Go ahead and replace them with good bolts or studs. Dont mess around or you could get burned.
Old Aug 21, 2008 | 01:18 PM
DRCE's Avatar
If you replace the OEM bolts with the ARP studs. Do take care to have the engine block's housing bore measured and align honed as needed.
Old Aug 21, 2008 | 05:16 PM
Halloran's Avatar
There may be dicrepancies as to whether or not the bolts and studs can be reused. However, I think it's unanimous that if an engine is line honed to have it done with the bolts or studs. Make your decision prior to the line hone and don't decide to upgrade to studs after the line hone is done without having it line honed again. Most machinists would agree with that. The studs put a different load bearing on the caps than the bolts do.
Old Aug 21, 2008 | 05:28 PM
Black01M6SS's Avatar
I would use the old bolts to check the clearances with then when you get done checking everything install the new bolts.
Old Aug 27, 2008 | 12:17 PM
slowjoe99's Avatar
Originally Posted by Randy WS6
You can get Fel-Pro stock head bolts at Advance Auto for 50.00 for both heads. Just trying to help. But if your planning to remove the heads in the future you need to go with ARP because you can reuse them over and over. ARP bolts will be the last set of head bolts youll ever buy.
main cap bolts not head bolts
Old Aug 27, 2008 | 09:09 PM
Wilde Racing's Avatar
How do I change this text
Thats how I did it..
TORQUE TO YIELD ARE NOT REUSABLE. You stretch the bolt to the point of no return..
