Royal Purple
Old Aug 23, 2008 | 05:17 PM
red02Hawk's Avatar
foams too much, my catch can always filled up with this oil the 2 times i used it. full out race car yeah go for it, street car not so much. for the price i would just use M1 or GC. in my opinion VR1 racing oil by valvoline my be the best bargain out there.
Old Aug 23, 2008 | 06:26 PM
StevieZ's Avatar
???? I never had that problem.
Old Aug 23, 2008 | 06:31 PM
Joshiedoom's Avatar
Pennzoil Platinum 10w30. Best off the shelf oil you can buy. Do research, get some UOA kit and dont belive a thing you see on TV. Royal Purple is worthless, and I used it for years...
Old Aug 23, 2008 | 07:47 PM
black01_WS6's Avatar
I wouldn't say RP is worthless just overpriced. It is a good oil, but seems to break down a little quicker than other oils. Pennzoil plantinum or the VR1 are good off the shelf oils.
that said I still run RP in my car as it is avaliable.
Old Aug 24, 2008 | 09:23 AM
seawalkersee's Avatar
Well...not the oil, but I had a problem with my tranny going into 1st (at the stop light) after the engine got to operating temps. It was right after I got the car and I drove it that way for about two months. As I drove it, it got worse. To the point I had to put it in 3rd, then 2nd, then 1st or I would not be able to start. I swapped the fluid (which looked to be in great shape) out for RP ATF and I immediately got results. It was almost instant that I could go back into 1st at the light. I think I got 30K more out of the tranny (it was two years) before I finally had a failure that I still do not know what happened. I think I broke something as the sliders came out of the tranny with the plug pulled. So, yeah...I think its worth it.
Chris
Old Aug 24, 2008 | 11:01 AM
JHL88's Avatar
well my dad used RP on his 02 dakota and he said he'd never use it again after being hooked on pennzoil platinum he said his engine ran louder and not as smooth. i was thinking to switching over at the time too but now im sticking with mobil 1
Old Aug 24, 2008 | 11:21 AM
caddobass's Avatar
I have ran RP 5/30 in my 2002 every change. The only time it was not RP was the first change the dealer done free. I will keep on using RP, I also use it in my 2004 truck. I LIKE IT!!!!
Old Aug 24, 2008 | 08:33 PM
scottbartlett's Avatar
Why Would You Throw Away Rp After 3,000 Miles. Its Not Even Half Way Used Up....
Old Aug 24, 2008 | 08:40 PM
johnLs1camaro's Avatar
i switch it also at 3,000 miles,i know they say you dont have to switch til like 12000,just change the filter and top the oil of every 3000 or something like that. but i would rather keep fresh oil in my car,and i spoil my car, shes worth every penny!!
Old Aug 24, 2008 | 08:56 PM
RP IS 5 TO 7 HP BETTER THAN ANY OIL YOU CAN BUY AT THE NORMAL PARTS STORE... IF YOUR RP BROKE DOWN FASTER , YOU WERE USING A FRAM FILTER.
Old Aug 24, 2008 | 09:51 PM
STALL UP's Avatar
RP is one of the best oil out there for preventing wear but I would only use it in a race car that does not see alot of heat cycles and gets changed every so many races. It really cakes/sludges up a street car. I had a thread on it after I took my stock 346 apart with like 42,000 miles the heads only had 12,000mi on them and everything was caked up. My buddies motor had 35,000mi with mobil 1 and was as clean as when new. I use rotella now and when I get the milage on the new motor I will start using mobil 1 with lucas oil stabilizer. if you was to read more on this search for me thread on royal purple sludge.
Old Aug 24, 2008 | 10:28 PM
  #32
84z28Camaro's Avatar
One of the thing RP advertises is high film strength, which means it sticks to parts. While it may seem good as it sticks to them to lubricate them.... do you really want something sticking to your engine parts? Oils meant to flow and go between to lube not stick to stuff.... and scottbartlett I hope that was sarcasm, or you've been reading their bottlesa little bit too much.
Old Aug 25, 2008 | 07:02 AM
  #33
LS1C5Vette's Avatar
I use it and change it every 3k also
Old Aug 25, 2008 | 07:29 PM
  #34
socmguy's Avatar
Restricted User
WTF?!! I would have bought it all too!
Originally Posted by b0pric01
yep, I used rp 5w30. I got a killer deal on it at autozone one day, for some reason the local autozone was getting rid of stock and I was the first one to learn about it. I got about 20 or so quarts for $1 each so I stocked up.
Old Aug 26, 2008 | 07:14 PM
  #35
NO I'VE BEEN READING THE HP #'S ON MY DYNO AND THE LOWER ETS ON MY TIME SLIPS
Old Aug 26, 2008 | 07:32 PM
  #36
BlueThunder2's Avatar
Royal Purple is a good oil, but AMSOIL is so much better. You can go to the web site below and read comparison test results or go to the Sponsors AMSOIL tab on the right.
As far as not seeing a difference between 10w-30 and 5w-30, that's because the number before the "w" is the weight in cold weather. 32 degrees and below. All of that information is on the web site as well. AMSOIL is also producing straight Racing Oil. Even oil for supercharged/turbo charged/nitrous vehicles.
There are also several people who have proven that they received better gas mileage with AMSOIL products.
Go to:
http://synthetic-motor-oilsite.com/1594448/
or use the tab on the right in the Sponsors' area.
Old Aug 26, 2008 | 08:17 PM
  #37
HAMRHEAD's Avatar
Anyone use the RP XPR oils? Was looking to maybe switch oil from VR1 20w 50.
Old Aug 26, 2008 | 08:26 PM
  #38
Haans249's Avatar
I'm using the XPR oil. It is really something else. It really holds up well to WOT runs, and keeping its viscosity when it gets hot, which is very important. Only down side is its Fu**ing expensive.
Old Aug 31, 2008 | 02:30 AM
  #39
JPH's Avatar
JPH
This OIL makes HP for sure ank helps engines LIVE longer. I am a avid user of R/P and love it.
Old Sep 1, 2008 | 01:10 PM
  #40
silverbandit0996's Avatar
save your money. oh and stop with the oil threads already.
