Lifter issues HEEEEELLLLLP
Had a problem with a customer engine this spring.
The pin for the roller decided to exit out one end of the lifter, gouging it into the lifter bore. I managed to remove it with a slide hammer with an expandable end that can grab the inside of the lifter body under its upper most edge.
This technique will guarantee damage to the length of the lifter bore as you are pulling it out the top. I don't know any other way to remove it other than engine disassembly first and try to push it down from the top. There will likely still be some degree of damage to the bore.
I pulled the motor, stripped it down and sent it off to be bored and sleeved with some fairly special mill/fixture (in a different city)
They also need to remove the cam bearings for the fixture.
Took a month to get it back, was expensive and the engine is still not re-assembled.
If you end up with similar damage, it may be cheaper/faster to just buy another new or used block.
BTW,
These were Comp-R lifters with very little time on them. Quality control?
You be the judge.
Condolences,
T
+1, No need to cause more damage by removing is through the lifter bore. You MAY also be able to see if ther is a loose roller pin by looking through the lifter bore next to it.
That's exactly what I'm doing. I'm going for more area under the curve this time instead of just top end, it should make for a faster ride.
