timin chain install
Old Sep 1, 2003 | 08:29 PM
pdd's Avatar
pdd
Default timin chain install
when i installed my timin chain i couldnt get the dots perfectly lined up. i moved the chain over one tooth and the dots were a little out of line. i moved the chain one tooth the over way and its a little off. what gives. will this be ok being a hair off????
Old Sep 1, 2003 | 08:50 PM
DaleMX's Avatar
Default Re: timin chain install
Make sure that the dot on the crank is straight up, and the #1 piston is at the top. The dots should line up.
Did you have the dots lined up before you removed the gear?
Old Sep 1, 2003 | 09:29 PM
pdd's Avatar
pdd
i didnt look to see if the dots were lined up when i took the chain and gear off. its off a hair.the dot on the crank is straight up.
Old Sep 2, 2003 | 12:04 AM
jmX's Avatar
jmX
You need to rotate the crank a little to the left or the right, and you'll eventually get the dots lined up 100% perfectly
