Sparkplugs for 243 casting heads (high compression)
Old Aug 23, 2008 | 12:19 AM
Schantin's Avatar
Default Sparkplugs for 243 casting heads (high compression)
Quick Q. Tuning my new HC setup. 243 heads (10.7 to 1 compression). Noted that the car does NOT like lots of timing (ie abov 24 degrees WOT and a little less than stock values pat throttle. Anything more = knock.
Running TR55 plugs. These too hot? Thinking maybe I should go back to TR6's. $0.02 appreciated.
Old Aug 23, 2008 | 08:18 AM
Shawn MacAnanny's Avatar
Go tr6
Old Aug 23, 2008 | 09:29 AM
JPH's Avatar
JPH
Autolite #5243 is a good starting point.
Old Aug 23, 2008 | 09:36 AM
Formulated's Avatar
With high compression and a lot of timing retard, you probably want to close down the gap a bit too. OE spec is 0.060", maybe try 0.045" to make sure you stay clear of misfire.
Old Aug 23, 2008 | 10:16 AM
99blancoSS's Avatar
A lot of guys go with the tr6 for hi compression
Old Aug 23, 2008 | 10:49 AM
Schantin's Avatar
Thanks for the info Sounds like I'll be putting the TR6's back in.
Old Aug 23, 2008 | 02:06 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
on the TR6s
Old Aug 23, 2008 | 08:35 PM
5_02ls1's Avatar
i went with a 7 range plug for n2o and im running a little more compression than you...I was having bad knock issues with the stock timing tables and the 6 range plug....I found stock ls6 timing tables and went with the colder plug and it eliminated my problem....high compression and pump gas = tuning
 Michael S. Palmer
Old Aug 23, 2008 | 09:38 PM
JBIRD02's Avatar
Originally Posted by Z28/2002
on the TR6s
yep, what he said
Old Aug 23, 2008 | 10:59 PM
Schantin's Avatar
Good info. I picked up some TR6's today. Family commitments kept me from installing them. Will do that tomorrow and see how she acts then
Old Aug 24, 2008 | 03:32 PM
Sigforty's Avatar
What gap are the current plugs at and how do they look after some WOT runs?
Old Aug 24, 2008 | 10:15 PM
Schantin's Avatar
The TR55's got swapped today......
But, to answer your Q, they looked light grey and the electrodes were fine. There was a hint of brown on a couple of the ceramics by the electrode, thus confirming sporadic knock.
The TR55's were gapped to .050.
The TR6's I just installed are gapped to .035.
Old Aug 24, 2008 | 10:17 PM
03 snake's Avatar
Originally Posted by JBIRD02
yep, what he said
Same here Tr6
Old Aug 25, 2008 | 08:13 AM
Sigforty's Avatar
Alright, you should be fine with the Tr6's. I started running the 6's when I went over the 450 rwhp range.
