HELP QUICK! Identifying an LS2
Hey guys, I need some help identifying an LS2. I am going to look at one tonight or tomorrow and I want to make SURE I am getting what I pay for. It seems I need to look for a casting number of 12568952, which should be located on the back of the block, kind of behind the flexplate. I also should look for 243 head casting numbers (which are stamped on the outside of the head right? You don’t have to pull the valve covers?) I read that some LS2s have 799 heads, what does that tell me? Finally, there should be a gray CPS to indicate that it has the 58x reluctor.
Is all of this information correct? Please let me know.
Thanks much,
Wes
Thanks much,
Wes
Thanks.
I was thinking that. So, if they all have it, why does that make it an LS2 specifc feature? I will make sure to check for the displacement stamping too, thanks. Those heads I listed (243s and 799s) are what's supposed to be on the LS2, right?
I really appreciate all your help.
Wes
ls1/6...5.3..the cam position sensor is in the rear of the block next to the oil pressure sending unit...block stamped 5.7
ls2/3/7..l92... is aluminum with the cam position sensor in the front timing cover..
ls2 stamped 6.0
ls3/l92 stamped 6.2
ls7 stamped 7.0
hope this clears up any confusion
ls2 stamped 6.0
ls3/l92 stamped 6.2
ls7 stamped 7.0
ls2 stamped 6.0
ls3/l92 stamped 6.2
ls7 stamped 7.0
ls2 stamped 6.0
ls3/l92 stamped 6.2
ls7 stamped 7.0
