383 package with MTI S2 LS1 Heads/X1 Cam?
Look for your 383 you should go for a big cam i have 383 stroker from the mti and my cam is Z1 its anew cam and it is agood cam that what the mti told me when i order the 383 i tray it its Avery good cam .and you can try it .you can keep your stage 2 heads its good don't go for bigger heads ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I would love an X1 in a 382. Talk about stealthy! It would still make great power. Just look what Nineball did with a T1 (much smaller than an X1) in a 382.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
look mr.colonel it doesn't mater if it is small or big you look at the duration when it is high the cam will be good look at the thunder cam the liftof ther cams are small but look at the duration you will see its big.it doesn't mater .
but i still like this cam the z1 cam it gives my car great power but what i wants to let you know that i have 383 all stroker not 382
Mr FireHawk, I'm a bit
by your post as I don't understand what it has to do with what I said in my last post.
Doesn't matter if what is small or big?
Look at the duration when what is high?
What doesn't matter?
And again, what does this have to do with my comment above?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Hey, no problem friend.
I just wanted to understand clearly what you were trying to say and also to make sure that you hadn't misunderstood anything that I'd said. It's all good.
