383 Sroker questions
Old Sep 3, 2003 | 02:52 PM
DG Gordon's Avatar
Default 383 Sroker questions
I am going to send my car to Texas Speed in the morning and have them look at it and posibly do a 383 for it. I was wandering for all who have done this do you like it or regret doing it? I already have heads and cam, I added the Yella Terra rockers and lost 15 or 20 rwhp so I am going to let them look at it and probably stroke it. Does anyone have any opinions on doing this pros and cons?
thanks DG
Old Sep 3, 2003 | 06:50 PM
kumar75150's Avatar
Default Re: 383 Sroker questions
Basically you are spending $2000 extra for a few more horsepower and a lot better area under the curve.
You need to decide whether you want that or not.
Old Sep 3, 2003 | 06:56 PM
Z-Rated's Avatar
How did you loose hp with the yella terras? BTW if you get a stroker motor your botom end is bulletproof
Old Sep 3, 2003 | 07:13 PM
CAT3's Avatar
Restricted User
Only way i could see losing HP is if:
1) you had 1.8 or 1.85 rockers before and now have 1.7
or
2) you bent a pushrod, or have something just a tad loose to maintain compression.
anyone else???
Old Sep 3, 2003 | 08:21 PM
DG Gordon's Avatar
I am going to install the spacers tonight and see if that helps any I have dynoed it twice and still down close to 20 hp. If I cant get the power back I am going to get the stroker I guess.
Old Sep 3, 2003 | 08:27 PM
2001 Pewter WS6's Avatar
Restricted User
You will have torque, torque and more torque. I am still trying to dial in my suspension to get all that power to the ground. I used to be able to hook with Heads/Cam and a 4400 converter on ET Drags.
