is the melling m295 and 10295 oil pump the same?
Old Oct 27, 2020 | 12:09 PM
ngc1068's Avatar
Originally Posted by G Atsma
True dat!
Sorry, about dredging up this old thread. I had used the search feature, and ended up starting off with an M295 based on the info that it was the same as a 10295, only to realize at the last minute it was a mistake.
I felt someone needed to post something to this thread to correct the early incorrect reply that said the two pumps were the same...it cost me two days and a return trip that could have been avoided, had the correct, informed responses (they are NOT the same) been on the old post in the first place.
Old Oct 27, 2020 | 03:27 PM
DO. NOT. APOLOGIZE!! YA HEAR??
LOL. Dude, it's all good! As was said, it's good info!
Old Nov 5, 2020 | 07:16 PM
TimsLS1's Avatar
I researched this to best of my knowledge the 10296 has heat treated internal gear the 10295 does not appear to after much searching I could not find anything to say it was and the 10296 is usually slightly more expensive.
Id be interested if anyone knows for certain.
I used the blue ring in my new engine with the 10296 and tuner said I had 90 psi.
Old Feb 12, 2021 | 10:00 PM
ngc1068's Avatar
the 10296 is a higher volume pump, at the same speed it moves something like 30% more volume of oil vs 10295. This extra volume of oil is meant for displacement on demand engines, not for a standard LS3. Most likely those with the 10296 on a non DOD build, have so much volume coming out of the pump, that the oil cannot pass through the engine passages, the pressure backs up to the pump and, the relief valve is constantly open, spring compressed, valve is shuttling jn and out of the valve bore, wearing...the pressure is high increasing stress throughout the pump casing...its not how it should be. Super high oil pressure would be easily achieved if OEMs wanted that...more is not always good.
Old Feb 12, 2021 | 11:50 PM
TimsLS1's Avatar
Yes I used the blue spring in my Hi volume oil pump for 90 psi in my newly rebuilt LS1 at about 6000 rpm. It was recorded while on the dyno. The red spring that came pre-installed in the pump would have given it even more PSI.
I wonder also if the additional pressure makes it more prone to leaking, I have an oil leak I need to fix.
Old Feb 13, 2021 | 09:28 AM
wannafbody's Avatar
I don't see that a higher volume pump is automatically better just because it moves more volume. If the pump moves more oil faster than it can drain back to the pan you'll have an issue vs a standard volume pump.
Old Feb 13, 2021 | 02:28 PM
TimsLS1's Avatar
I've seen a debate that it isn't possible with a hi volume pump. The more oil pumped the more oil returned to sump. That is a different problem from what can occur in hard corner and low oil in sump. Unless the oil is going to do a gravity defying feat and a quart or so is going float around in the top of the engine somewhere it will return.
I have a small oil pan and a baffle to keep oil near the oil pickup when cornering, the baffle makes it harder for the oil to return to the sump with my hi volume pump, not enough to matter though, the cornering is the problem.
I guess I'm asking if it would take one, two or ten high volume oil to pumps to pump enough oil for it not to return to the sump quickly enough, I'm guessing ten of them wouldn't be enough.
