Mild clattering from top end - problem or normal?
Old Sep 6, 2008 | 09:15 AM
LS1Formulation's Avatar
Default Mild clattering from top end - problem or normal?
I have a TR 224 cam, uncut heads, and 7.400" pushrods. I just installed a set of Patriot Gold springs and I'm noticing a bit of clattering from the valvetrain right above idle - either if I just blip the throttle and let it fall back down to idle, or if I hold it steady around 1300-1500 RPM. This happens primarily after my oil gets some heat in it. If I raise the RPM a bit more, it goes away. I'm just curious if it's just slack in my valvetrain because the lifters haven't fully pumped up, or if I need to pull it apart and check to see if the rockers have loosened up a bit.
Old Sep 6, 2008 | 10:00 AM
98Camarod's Avatar
If its clatter then somethings not right. If its a sewing machine sound then you are most likely fine. Are they dual springs?
Old Sep 6, 2008 | 10:19 AM
Yeah, it's more like a sewing machine sound. They're dual springs with about 30-35 pounds more seat pressure than what I had on there. I'm guessing that the additional seat pressure is overcoming the hydraulic pressure in the lifter at low RPM.
Old Sep 6, 2008 | 11:44 AM
DaddySS's Avatar
If you didn't measure and get the perload correct you should do that.
Old Sep 6, 2008 | 11:47 AM
snake charmer's Avatar
aftermarket springs are going to have sound with them . pull the valve covers and check it out just to be safe but more than likely it is just the valvetrain noise .
Old Sep 6, 2008 | 12:38 PM
98Camarod's Avatar
If it sounds like a sewing machine, youre more than likely alright.
