Cleaning tops of piston durring H/c
Old Sep 5, 2008 | 03:14 PM
wilwhite2kss's Avatar
Default Cleaning tops of piston durring H/c
Does anbody clean the tops of their pistons during a heads/cam install? If you do or dont , please explain how , and why or why not
Old Sep 5, 2008 | 03:32 PM
Black_Jack's Avatar
my brother does he tapes off the other cylinders and brings 2 pistons to the top and usess a wire bruch to clean them off and then sprays it with a air hoes.. and then does it to the others
Old Sep 5, 2008 | 03:33 PM
Pharcyde50's Avatar
Gasket remover works like a champ to get the carbon off.
Old Sep 5, 2008 | 03:42 PM
98Camarod's Avatar
I brought each cylinder up to the top and used a gasket scraper. It's carbon buildup.
Old Sep 5, 2008 | 05:37 PM
davered00ss's Avatar
Moderator
Spray in CRC brake cleaner or Carb cleaner and scrub with a rag.
Old Sep 5, 2008 | 07:39 PM
themack56's Avatar
that dosnt work
Old Sep 5, 2008 | 07:43 PM
stoverz28's Avatar
Just curious, why do you guys do this?
Seems like a waste of time to me. The carbon will be right back after the first time it fires so whats the point?
Old Sep 5, 2008 | 08:17 PM
LS1 Life's Avatar
I figure the more carbon buildup the higher your compression ratio and more power!! ha just kidding.. i never do it
Old Sep 5, 2008 | 08:25 PM
SSPerformance's Avatar
leave it alone your asking for problems.....
Old Sep 5, 2008 | 09:02 PM
Bill Bowling's Avatar
I always clean the carbon off. I used a scrapper and cleaner. Just make sure you get all the gasket stuff out of the holes and cylinders.
Bill
Old Sep 6, 2008 | 04:47 AM
james562's Avatar
Brake cleaner is flammable as a ****, if any of that seeps past your rings you could have some fireworks coming out of your bottom end on the inital start up.
I brought each cylinder up to TDC and used a razor blade to get all the carbon off.
Old Sep 6, 2008 | 07:46 AM
vettenuts's Avatar
How do you measure PTV with carbon on the piston? Most don't measure is likely the answer.
Old Sep 6, 2008 | 07:58 AM
01Z28M6's Avatar
Carbon in the combustion chamber causes detonation. The carbon retains the heat (actually glows) after the charge has been exhausted and greets the incoming charge.
My advice about cleaning the tops; don't use any liquid. It will carry the tiny granules into the ring area. where you won't be able to get it out aside from disassembly.
I first moved the piston down in the bore a few inches and put a very light coating of oil around the cylinder with my finger. The piston was then moved to TDC where it actually protrudes above the deck a tiny amount. I masked all the holes with towels and tape and proceeded to used a small putty knife where I had carefully removed all sharp corners. I had a shop vac on hand and running to suck up the particles as they became dislodged.
Old Sep 6, 2008 | 09:43 AM
chrs1313's Avatar
cleaned mine with degreaser and a brillo pad worked great...
Old Sep 6, 2008 | 10:05 AM
JFM-jr's Avatar
Sprayed some carb cleaner onto a rag then used elbow grease, worked 100% perfect.
Old Sep 6, 2008 | 01:21 PM
dz999's Avatar
I just scrap with a good flat gasket scraper. By sure not to gouge the aluminum of the piston tops. I then blow that cylinder out with compressed air after covering all the other cylinders. The carbon takes a while to build up; I think it's a good idea to remove every time you have access to the pistons.
