Few cam supporting mod question..
Old Sep 9, 2008 | 08:02 PM
Zach79Z's Avatar
Default Few cam supporting mod question..
I decided to go with the VRx6 (238/240 .605/.609 112 LSA) cam from Vengence and i was wondering with this cam will i need to get bigger fuel injectors? What about piston to valve clearance? I allready have picked out ls7 lifters, Patriot dual gold valve spring kit (.650 lift), ls2 timing chain, Yankss3600 stall, Ported ls6 oil pump, and full bolt ons (saving up for fast 92/92). Is there anything im leaving out?
Old Sep 10, 2008 | 05:09 PM
Zach79Z's Avatar
Anyone?
Old Sep 10, 2008 | 05:26 PM
teke184's Avatar
heres and idea....ask the manufacturer about PTV on the cam...
but i think you'll be fine if you leave the stock heads and gaskets in there.
why are you going through the hassle of changing the lifters? why not wait till you can upgrade the heads?
