5.3 heads ?
Old Sep 5, 2003 | 06:56 PM
johnster's Avatar
Default 5.3 heads ?
If you put a set of stock 5.3 heads on my 98 ls1 will I see any power gain?They have 918's springs. Thanks
Old Sep 6, 2003 | 12:37 AM
johnster's Avatar
Default Re: 5.3 heads ?
ttt
Old Sep 7, 2003 | 12:40 AM
TEA Brent's Avatar
No you will not, they have a very shrouded 3.800" combustion chamber and 1.89 diameter intake valves. The heads need a minimum of chamber work and a 2.00 valve to make more power then the stock 5.7 heads, and this power is mostly due to increase in compression. You need to get a set fully ported to take full advantage of the 5.3 casting.
