cleaning inside of block.
Old Sep 11, 2008 | 06:22 AM
SheldonZ28's Avatar
Default cleaning inside of block.
Hey Everyone.
Im picking up a used LS1 block for my build. Id like to clean the block completely inside and out.
What would i use to clean the oil tint off the inside of the block?
Brake Cleaner? Engine Degreaser? Super clean?
Thanks!
Old Sep 11, 2008 | 09:31 AM
Halloran's Avatar
I know many guys that use lacquer thinner and of course carb cleaner is always a good friend.
Old Sep 11, 2008 | 05:24 PM
84ls1_transam's Avatar
Soap and water work very well too. Esecially if you are honing. It is the only real way to get out all the metal. I use soap and water, and a little simple green.
Old Sep 12, 2008 | 09:01 AM
KCS's Avatar
KCS
Moderator
Wire brush, preferrably before machining.
Old Sep 12, 2008 | 11:53 AM
witry's Avatar
hot and very soapy water only dont use and carb or brake cleaner they all leave residue once they are dry clean it with soapy warm water then soak it in wd-40 and you will be fine
