dome pistons
Old Sep 11, 2008 | 06:16 PM
silverbandit0996's Avatar
Default dome pistons
why does no one hardly run dome pistons? i know they were popular years ago, but they aren't even mentioned on this forum. is it just not in style to gain compression through dome pistons, or is there a legit reason no one runs them?
Old Sep 11, 2008 | 06:36 PM
SOMbitch's Avatar
Because flycutting or valve relief pistons are the best way to gain compression and have adequate PTV clearance.
Old Sep 11, 2008 | 06:38 PM
SLowETz's Avatar
You mean like this?
Old Sep 11, 2008 | 06:46 PM
s346k's Avatar
i'd guess because the stock pistons are already 8-10 thou out of the hole. domes aren't really needed when you can simply use smaller chamber heads and reliefs. too much of a dome will f up the burn. search quench.
Old Sep 11, 2008 | 07:21 PM
DONAIMIAN's Avatar
There's not really a need for domes. Although. with the new big chamber heads (ls2 and L92) im starting to notice a few.
Old Sep 11, 2008 | 08:27 PM
SOMbitch's Avatar
Originally Posted by SLowETz
You mean like this?
PUUUUUURTY
Old Sep 11, 2008 | 08:31 PM
SOMbitch's Avatar
Think you are right. Stock an LS1 is 7 thou outta the hole normally.
