Just installed Fast 92/92 set and having problem's
Old Sep 12, 2008 | 06:15 PM
1FASTBIRD's Avatar
Angry Just installed Fast 92/92 set and having problem's
Just finished the install and the car is idleing at 2 grand. The idle would drop and go back to normal but when I push the gas the car would cost and it's an M6. I don't even have to push the gas because once I do to take off it drive's by itself. I don't know what the hell is wrong or what we did wrong. PLEASE HELP
Old Sep 12, 2008 | 06:21 PM
THENASCAR's Avatar
vaccum leak. make sure nothing is caught under the manifold.
Old Sep 12, 2008 | 06:23 PM
primer84z's Avatar
you swapped the bolts on the valley cover right? Check the IAC solenoid, and for obvious vacuum leaks (the HVAC line, brake booster, MAP sensor). Check the TB blade to make sure it is closing all the way with the throttle cable hooked up, then check the TB itself. I tried using a TPIS TB and it just wouldnt idle, it was letting in too much air. I had the same problem as you almost, and switched to a bluemaxx and the problem was solved.
Old Sep 12, 2008 | 06:25 PM
quikrnmost's Avatar
It could be a number of things. It's possible your computer & IAC need a little time to figure out the extra air being available. It could fix on its own or you might try an IAC reset.
The other potential is an air leak around the manifold, tb, or the throttle body is allowing more air than normal around the blade. You can spray some carb cleaner to find a leak or try adjusting the idle set screw to close the blade a little.
Old Sep 12, 2008 | 10:39 PM
oscareltemblo's Avatar
I was having the same problem when I put my l92 heads and 90 mm TB I had to adjust the tune because it is taking in more air than before at less of an angle on the TB.
Old Sep 12, 2008 | 10:51 PM
brad8266's Avatar
Air vacuum leak no doubt. Find and fix the leak. This has nothing to do with tuning or relearning or anything like that.
Old Sep 13, 2008 | 12:55 AM
1FASTBIRD's Avatar
Ok thanks guy's for the help and I hope to get this fixed by tomorrow...
Old Sep 13, 2008 | 03:30 PM
Redlinez's Avatar
Make sure you double check all your bolt torques so none were left loose as well. It would also be possible one of those intake gaskets popped out or slid out and is pinched.
Old Sep 13, 2008 | 03:41 PM
transam69230's Avatar
Check your map sensor too, sometimes they come out or aren't sealed properly. Fast intake doesn't really hold the map sensor in very well. You can tap the intake with a barbed fitting and then run some vaccum hose off of the barbed fitting and sticking the map sensor in the other end. Thats what i did, and haven't any problems.
Old Sep 14, 2008 | 01:19 AM
NXZ28's Avatar
You need adjust the idle on the throttle body. If you are idling at 2K and it takes time for it to drop to normal then you need to back the idle screw down on the throttle body. Vacuum leaks can cause it too but I would start with the idle adjustment first.
Old Sep 14, 2008 | 10:12 AM
eamador11's Avatar
I agree, when i put on the FAST 90/90, my cold start up would shoot to 2k, then finally settle down. Doug at ECS readjusted IAC settings more t compensate the additional air. He said he was surprised because I was already below stock settings but he also said you have to follow what the car wants. been fine ever since.
Old Sep 14, 2008 | 10:28 AM
35th SS's Avatar
mine would hang@1500 rpm and drop back down to 900-950.left it alone for a couple of days and driving and it adjusted on its own back to normal of 950 rpm.yours sounds like a idle screw adj. on the tb.
Old Sep 14, 2008 | 05:59 PM
1FASTBIRD's Avatar
Posted updated thread.Thanks
