Meziere water pump wiring??
How are you all wiring your your water pumps.????
My car is a street/strip car so i would like to have a manual override to go with my fan switch.
If you can please do up a wirring diagram
thanks
thanks
All you need is "key on" power to the relay trigger & you can connect your overide switch between the "key on" power source (10 or 15 amp power w/ key on) & the relay, if your overide fan switch doesn't require "key on" power. If your overide fan switch does require the key to be in the on position, then jumper from that "key on" power source to the relay trigger. Then a low current ground for the trigger.
Then run 30 amp power from battery to the relay & a ground wire sized to ground 30 amps. Then run the 7.5 amp fused water pump power line to the relay. Sorry, I have no drawing, but, I think that Meiziere has a wiring diagram posted on their site. Their diagram will clear up where to connect to on the relay.
