Need Advice ''what cam'' ?
Old Sep 15, 2008 | 06:23 PM
Mohammed's Avatar
Exclamation Need Advice ''what cam'' ?
I have a '99 z,m6 (weekend driving)
car has boltons,mods in sig
I want a cam that gives me good numbers(HP)..I'm planning to stay stock heads so far..until next year..and in the future maybe i'll go with a supercharger...I do some street racing
I may use nos(maybe) not sure
one guy told me to go with 222/228 .571/.578 114º LSA as he said " works well naturally aspirated and work with a centrifugal blower well "
other one said "A 226-234 cam on a 113 LSA would be the best one to run all around"
I dont want to change the cam when it comes to get new Heads..(saving few bucks)
what cam do you guys recommend ?
do I have to change the ls6 to 90 FAST intake ?
one guy told me that a good cam will have an overlap between 1-5 ? is that true ?
Thanks in advance
Old Sep 15, 2008 | 06:31 PM
firefighter813x's Avatar
Contact a professional like Patrick G, Predator-Z, or some sponsors and have them spec a custom cam for your needs. I have a off the shelf cam like many people on this site, but would go custom if I did it again. More overlap will give it that chop sound. Judging by your questions, use the search button and ask someone mentioned above.
Old Sep 15, 2008 | 07:41 PM
SlayerMaro's Avatar
^Agreed, both of those two guys know their stuff about cams. I would trust their opinions on my car.
Old Sep 15, 2008 | 09:28 PM
BlackScreaminMachine's Avatar
Internet Mechanic
You can get a custom spec.
See my sig, I run a VRx4, 228/230 on a 112 LSA, runs extremely well. Makes just under 400 rwhp through a heavy driveline. Makes for a FUN street car.
Old Sep 15, 2008 | 11:08 PM
PREDATOR-Z's Avatar
Now, here is the trick, you want a good cam that will work NA and then 1 year later on a Supercharger.
224/230 .609/.604 112+2 LSA
That will be the ticket for both, 3* overlap, exhaust biast, 42 IVC (6200 rpm peak with LS6), the XFI lobe will act like a 228 duration on intake. Power range 1800>6600
intake lobe 3015r
Exhaust lobe 3036r
112 LSA
110 ICL
If you like, those are the specs you can give to a shop to get it ground.
Old Sep 16, 2008 | 12:52 AM
SlayerMaro's Avatar
See, this is why I should have asked you about what I should do instead of buying an off the shelf cam.
Old Sep 16, 2008 | 08:34 AM
Mohammed's Avatar
is your car a daily drive ? how it's idle
Old Sep 16, 2008 | 08:45 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
What your asking for is a little bit tricky. It's hard to just make up a cam spec without more information about your current combo & what your boosted combo will look like. I'd be more than happy to help you select a camshaft for your application, but I'd definately need more information before I went spec'ing a camshaft off a couple statements....
Give us a call & we can discuss possible options for you.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Sep 16, 2008 | 10:10 AM
Mohammed's Avatar
Thanks for passing by..
what exact information do you need ..I can't give you a call it's gonna cost me a fortune..lol
Old Sep 16, 2008 | 10:13 AM
Mohammed's Avatar
intake lobe 3015r
Exhaust lobe 3036r
112 LSA
110 ICL
thanks man..pm sent requesting some info
