roughly how much power will i make?/help
With a stock bottom end, good flowing heads, large cam, LS6 intake, headers and the rest of the supporting mods, you can easily be in the low to mid 400's rwhp range.
is the slp maf worth it or just run stock for the time being?
idk if i'll beable to run a decently sized cam(ms3 or ms4) with the big valves. the bigger combustion chambers are big and they are 6.0 heads going on a ls1.
the heads have been decked so that'll help along with a thin headgasket. think i can still pull it off?
my friend is completely confident that i can.???? idk.. idk..
screw the Ls6 intake. FAST 9x/9x would be the way to go...
i have Patriot Stage II heads, FAST 90/90 and a little Comp 224 putting down 458/410...
im really against fly cutting the pistons. idk why but i just couldnt get myself to do it.
i was gonna go with the ls6 intake for breakin and tune. then save up and get a throttle body and intake. i was thinking the 92mm big mouth and 92mm intake to go with. idk if thats what you described but it sounds good to me.
the only reason why i was going with these heads was they are available and i got a deal on them.. it was either these or stock ported ls1 heads. which i did the math and by the time i ported the stock ls1 heads got springs and put it all together i would have spent the same amount of money.
I think you can send them out for porting for ~$600 for more ponies.
As far as springs, I would run PRC dual valve springs. I believe they are rated up to .660" lift.
FYI, I know a buddy selling a low miles MS4 for $275.
damn i might have to pick that up. lmk if he does you'll have to ship to florida though (33764)
anyway i'll probably do that. i doubt i'll port them because i dont have the money for that. down the road i might who knows.
check out the updated set up and estimate my power again
thanks anyway i'll probably do that. i doubt i'll port them because i dont have the money for that. down the road i might who knows.
thanks
JK.I have been reading, researching, and wrenching for a while, and I still don't know as much as I'd like to. You never stop learning.
