At what point do i need RR?
Old Sep 16, 2008 | 09:41 AM
lilicedout24's Avatar
Question At what point do i need RR?
ok i have a 1999 Ta H/C 346 100 shot etc... when do i need RR and what benifit i tryed to search but all i get is what type is best ,vs etc... or if any did a better search then me a link would be fine thankx
Old Sep 16, 2008 | 09:47 AM
MM98's Avatar
You only need them if you run a set of TFS heads.. Otherwise the stocke ones are just fine.
Old Sep 16, 2008 | 11:39 AM
99blancoSS's Avatar
You could/should have your oem rockers rebuilt by Harlan Sharp and then they are good to go.
Old Sep 16, 2008 | 12:01 PM
ok thankx. so useing them do you get any gains or just for strenth?
Old Sep 16, 2008 | 07:24 PM
SOMbitch's Avatar
The big advantage with HS is they won't ever puke the needle bearings.
Old Sep 16, 2008 | 07:53 PM
JRracing's Avatar
With a shaft mount you get better stability at high rpm's. And with adjustables you can control the preload and wipe pattern.
An old SLP ad claimed like 10 or 20 hp. And tony mammo did a 383 build and at the end put on a set of RR's and gained a nice little amount of power. I'd have to look it up in the dyno forum.
Old Sep 18, 2008 | 10:26 AM
i think ill get me a set thankx
By Brett Foote | 2026-06-04 05:00:17
