Valve Springs
Old Sep 17, 2008 | 03:48 AM
Pete walsh's Avatar
Default Valve Springs
Are all of the stock LS valve springs interchangable?
i.e. LS7 springs on a LS1 head?
Old Sep 17, 2008 | 10:16 AM
Pete walsh's Avatar
any one?
Old Sep 17, 2008 | 12:19 PM
cammedss2000's Avatar
I put ls7 lifters in my ls1. I would assume that you could but I am not sure how good they are you should just get comp cams or something. I dont know just trying to help but if you found some place to order them from then just ask them.
Old Sep 17, 2008 | 12:28 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I believe stock LS7 springs use a different installed height than stock LS1 springs. You'd have to play with that, but I believe the diameter is the same.
