People with TR224 cams or 224 XE-R cams come inside..
Re: People with TR224 cams or 224 XE-R cams come inside..
I am dynoing a couple cars this afternoon and I'll bring a graph from an XER 224/224 cam only car installed at 0 (112ICL), if I remember it peaked around 6300. Made 396/388 with Jet Hot LTs/ORP, stock heads/TB/MAF and no pulley, 2002 WS6 M6 with stock 3.42s.
My 222/224 112 XE at 110ICL is here in a .txt file, easier then looking at a tiny graph, I'll get you some XER numbers a little later..
http://personalpages.tds.net/~kpevin/numbers.txt
Here is a stock headed '02 224 112 XER, I looked at the cam card and it has +2 ground in, it wasnt degreed in though - stock chain/gears.
http://personalpages.tds.net/~kpevin/224.txt
http://personalpages.tds.net/~kpevin/224xer.jpg
If you can figure out where it peaks exactly more power to ya
