Need Help Bad CPS?
Old Sep 28, 2008 | 11:17 AM
jds99camaross's Avatar
Exclamation Need Help Bad CPS?
I was running at the dragstrip and on my 3rd pass on nitrous the car just completely shut off when i went through the traps. No sputtering or noise. Now it will not fire, I also checked the injectors and they are not polsing. I am getting power to each coil pack, but not out the ignition wire side on both banks. There was also fluid from what seemed like a hole in a hose. When I stopped the and popped the hood, I could hear the radiater boiling but the temp. guage was at 210. I checked to make sure it wasnt a blown head gasket and its not. I am baffled and would like some help.
Old Sep 30, 2008 | 08:00 PM
it was a bad cps. the fluid came from the radiator. I have bad luck, both problems at the sametime on my last pass.
