Solid Motor Mounts-What to use on the A4 trans mount ?
Old Sep 10, 2003 | 07:25 AM
jfm's Avatar
jfm
Default Solid Motor Mounts-What to use on the A4 trans mount ?
Should the trans mount be changed with the solid motor mounts,what type trans mount to use in a automatic[4L60E]?
Old Sep 10, 2003 | 09:52 AM
robertbartsch's Avatar
Default Re: Solid Motor Mounts-What to use on the A4 trans mount ?
i think the trans mount is the same auto/m6...
i suggest a poly mount....thunder racing has them...------------->
Old Sep 10, 2003 | 11:05 AM
JS's Avatar
JS
poly,no solid....
Old Sep 10, 2003 | 11:12 AM
Agree, solid mounts will likely trigger your knock sensors; right? ...stick with the poly mount...
Old Sep 12, 2003 | 05:22 AM
jfm's Avatar
jfm
OK,so I should change the 1LE,SLP rubber mount to a poly when the the solid motor mounts go in,correct?
Old Sep 12, 2003 | 07:43 AM
Ron@Vengeance's Avatar
Im running a stock tranny mount with solid mounts with no issues so far.
Old Sep 12, 2003 | 04:31 PM
Jorday's Avatar
The poly trans mount drove me nuts in my old car.
