CAM for roll racing ms4,trex etc...
If the guy wants a T-Rex or MS cam he should get it, but if he wants a GOOD daily driver then he should open his option list a little
LS1Tech Premium Sponsor
Sure he was, re-read his post (added below so you don't have to search far.) He posted what he wanted in 2 different posts.
You can look and see the dyno graph from our engine dyno time where the stock camshaft made better power down-low than any other camshaft tested. Does that make it better for a DD street car??? Should everyone stay stock because of it? NO. I've said it a million times here as well that there are better camshafts for many DD folks, and that the MS4 is a race cam designed to pull all the peak power possible from the stock long-block.
The fact is that on a roll race the OP is asking about, with the proper combo of gear/stall in the car, there is VERY little need for massive power under 4K RPM. And then comes your argument of needing gear/stall to run an MS4. OF COURSE YOU NEED MORE GEAR/STALL FOR RACING!
See yall at the race!
looking to start modding my vette i would like to start with tsp headers and i already have a blackwing intake after the headers id like to do a cam ive already decided on tsp comp kit for the springs etc... i just need help on the cam choice i dont do track or drag racing just highway fun and roll racing so i need something that will have good top end and be reliable on the street as it is my daily right now. I want a sick idle if possible i was thinking ms4 but like i said im new to gm not sure how the car will take it. any info would be great ps i heard predator z helped one of the ls1 buddies with a roll racing specific cam which is what i want. oh and i have an 01 6pd c5
Yes Texas Speed sells smaller cams than the MS4 that perform better but no one sugested one of those. jon fro TSP has said on another site that the MS cam will not perform with the smaller better speced cams down low. And should we talk about the TSP head cam car that got out run by a stock car on the street roll racing. Jason was having a hard time believing that also for some reason. SVT-Vette said the car is his daily driver so a cam that works well all around would be better than something that starts pulling at 4000/4500rpm's.
And by the way, I didn't mention TSP I just said he didn't need a over rated under performing cam. Way to step up there Matt and claim it.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I am actually looking for the same type of camshaft except my car is light, only about 2600lbs it has 4.10 gears and a 25" tire. So its pretty short final drive ratio. I dont want to lose from a roll.
I dont daily drive the car and its more a weekend/race car and I dont mind having a rough ride. I just need to be able to take off from a stop light witout stalling every other time, and be able to inch through a drive through without stalling. The other requirement is that I need to be able to go into 6th gear on the highway at 75-80mph and not have any bucking.
Some bucking and stalling is to be expected but if its something I learn and adapt my driving style to, so that it happens only if I'm not paying attention.. then thats fine. But if I adapt my driving sytle to the car and learn to drive it and its still stalling unexpectedly.. then thats too wild for me.
I will be going SD tune more than likely I would assume
Just have someone spec you a good cam and you wont have to adapt your driving style. The two cams in this thread can be tuned to not stall at stop lights and such. You can get most of the bucking out also, but I don't fill that a 239 intake duration or bigger cam is needed in a stock cube street car.
I trust his judgement, and deff realize the tuner knows more than me.
im the same way....i think donkey dick cams are a waste for anything other than race cars. but the OPs original post said that he wanted a "roll" race cam, which to me power under the curve is irrellevent in this case and peak hp is where its at. ms4 or trex would be good options as well as a custom ground cam. either way peak hp is a must in his case
friend has a f13 and 5.3s.. along with supporting mods, as intake stall gears..
i have ms4 and 90/90.. no heads....
i trap about half a mph faster than him...
i LOVE my ms4.. if you have a good tuner the street driving isnt a problem... i DD mine aout 50-60 miles every single day... no bucking stalling jerking or anything or that nature.. sounds sick and pulls like a freight train up top.. where most small cams die off around 100 or so some of the bigger cams just start coming to life.. roll races.. ms4.. DD.. ms4.. track.. ms4...
and of course i am biases but i have only seen good things from this cam... DD it dynoing it taking it to the track... whatever.. it has went beyong expectations..
What MPH are you wanting to roll from? That has alot to do with cam selection aswell. A 30 roll with an MS4 and stock rear = losing money to that 16 year old in the honda. Theres nothing more embarassing than trying to wait for your rpms to climb so you can make power.
A 30 roll with MS4 and gears = losing money to the guy with a mild cam. While your spinning your hard earned dollars away in tires he's a football field ahead and thats alot of ground to make up.
Oh and to the guy that does every type of racing in his MS4 only car good for you, I'm glad you like to lose mid range during auto x. Do a cam swap and watch your times drop considerably. Have you owned anything other than an MS4? It's time to get the ***** off your chin buddy.
The point is there are more than just monster cams out there and alot of them are making some damn good power. If you wants whats best for you then get one made for you. Listen to the guys that do this **** for a living, not an overpaid salesman force feeding products down your throat.
No Matt I will not be there, and don't really care to go. I'm going to assume your taking a race car to the Shootout, not a street car like the guy in this thread has. He wasn't asking for a cam that only pulls from 4000 rpm up. Yes Texas Speed sells smaller cams than the MS4 that perform better but no one sugested one of those. jon fro TSP has said on another site that the MS cam will not perform with the smaller better speced cams down low. And should we talk about the TSP head cam car that got out run by a stock car on the street roll racing. Jason was having a hard time believing that also for some reason. SVT-Vette said the car is his daily driver so a cam that works well all around would be better than something that starts pulling at 4000/4500rpm's.
![GTFO](https://ls1tech.com/forums/images/smilies/gtfoslap.gif)
#32
oh just noticed this fool is a self proclaimed tuner... thats why he hates on the bigger cams. Bigger cams and tuning becomes KEY. If you cant tune stick with small cams...like this monkey
#33
definitely not for roll racing (roll racing is gay) or any type of racing like the OP posted.
if you want to pull a trailer you need downlow power like your baby 224/228 cam
lol take a small cam and a big cam start them from a slow roll in 2nd at 1500rpm and watch the big cam just walk away even with all that "loss" of downlow power. no there is no loss, about the same and just a bigger hit in the middle and up top with a properly spec'd bigger cam. My cam is around 23x/24x 600 lift 113.5lsa (cant share custom spec) and let me tell you.. I have a massive hit at 3500rpms all the torque I need. Cant even hook up. Above that to 7k just lovely.
#34
#35
Oh CraZee06 congrats on being the post ***** of the day!!!!
#36
Thats really funny cause in my 4500lbs 4wd brick I put bus lengths on my buddys T/A. He has an LS6 intake, lid, full exhaust and the end all be all MS4. See my mods in sig. Pick an MPH and ill pull 4-5 cars, in fact at a 70 roll I'll pull 5-6 cars all the way to 130. With the bottle it's like 8-9 cars.
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
#37
I now use a 222/222 cam. i had a 231/237 the smaller cam has a huge amount more torque. on the racing circuit i gained 6 sec, don't know about the strip yet but it pulls way smoother and harder up to 6500rpm
#38
#39
your comparing your truck with HEADS and other mods vs a CAR with diff mods and a ms4 cam no heads..ls1 heads. thats a horrible combo. I find it funny people who put big cams on stock heads that dont flow, thats a bad combo.
you need a MATCHING cam to matching heads. Got heads that flow big then you can run a bigger cam, simple as that and you will see big benefits at the end.
