10.50's with this "mild" 383 setup?
Old Oct 3, 2008 | 05:15 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default 10.50's with this "mild" 383 setup?
if my block isnt messed up im going to reuse the stock block. cleaned up with a slight hone.
scoggin dickey 383 stroker kit
going to try and get as close to 11.1 without going over
231-234 610/610 11+2 custom cam
dart pro1 225cc heads with a "mild" port job
fast 90 with a NW90
30# svo's with a new fuel pump.
kooks 1 7/8 headers
3400 stall/ th350 with 4.11 gears. rev limiter will be 7500
you think this is 10.50's worthy?
ill prolly switch to a 6 speed so i can use it as my DD
Old Oct 3, 2008 | 05:41 PM
ndfrsd6's Avatar
sounds like you should be close ,what will your weight be ?
Old Oct 3, 2008 | 05:42 PM
ndfrsd6's Avatar
once you switch to a six speed though it a hole diff ball game
Old Oct 3, 2008 | 09:04 PM
nobreaks254's Avatar
Dont expect it to last long spinning to 7500. With that small cam you have no reason to spin more than 6700. BTW, I'm no expert, just giving my opinion. In my 383 with a 238/240 cam, rev limiter is 6900.
Old Oct 4, 2008 | 12:57 AM
silverbeast's Avatar
it wont stay together long at 7500 rpm's unless it is put together RIGHT. I would shift around 6800-7000 at the highest and you will be happy. I dont think it has 10.50's in it unless your race weight is kinda light, but you never know, build it and find out...good luck.
Old Oct 8, 2008 | 11:03 AM
blackls1ta00's Avatar
add another 100 hp and better converter and lower gears u might
Old Oct 8, 2008 | 11:10 AM
02 BLK WS6's Avatar
I don't think 30# injectors are big enough either.
Old Oct 8, 2008 | 11:16 AM
kdavis's Avatar
converter is a lil low. i could see low 11s out of it though
Old Oct 8, 2008 | 12:41 PM
s346k's Avatar
i don't see a 10.50 out of that setup. you'll have to trap like a madman to make up for the weakass 60' from that converter. not to mention...if it's going in a 3300+lb fbody - hahaha no way. why the high rev limiter? that cam will fall off long before 7k in a 383. if you upped the cam to something in the high 240s and got a 4000+ stall i can MAYBE see 10.70s with a hard hook.
Old Oct 8, 2008 | 12:45 PM
nofxrxmxpx's Avatar
i dont see a 10.50 with a 6 speed on that setup. MAYBE... with an auto. but i see low 11's.
Old Oct 9, 2008 | 07:43 AM
9secondsflat's Avatar
that cam will be done at 6500 for peak power, there are better heads than Dart (unless you already have them)
you will need to be high 1.40's to have even a remote chance. suspension- hole shot will play a HUGE role in how low your e.t is.
