Need help....LS6 intake install question
Old Oct 3, 2008 | 09:09 PM
neil1b's Avatar
Default Need help....LS6 intake install question
Hi,
I swapped out my ls1 intake for a ls6. I followed the instructions on ls how to and purchased the two coolant plugs and crossover tube as suggested.
When I removed the old coolant line I noticed these two small metal gaskets underneath the rear lines but not on the front ones. The install guide said nothing about these and the front ones were not there.
I installed everything with out the back to as the plugs had a rubber oring piece built in on them.
It runs and I don't see any leaks, but after reading on TR's website it lists the part number with (4 required)..................20-12551933 GM LS1 Coolant Seal (4 required)
Any ideas
Thanks in advance
Neil
Old Oct 3, 2008 | 09:58 PM
LS184's Avatar
you wouldnt have any problems if u would have just grinded down the ribs
Old Oct 3, 2008 | 10:02 PM
94'BLKBRD's Avatar
Great advice
Old Oct 3, 2008 | 10:04 PM
LS184's Avatar
Originally Posted by 94'BLKBRD
Great advice
same to u smart ***
Old Oct 3, 2008 | 10:07 PM
LS184's Avatar
Originally Posted by neil1b
Hi,
Any ideas
Thanks in advance
Neil
should b fine, when i did a buddys; he just had the plugs and crossover pipe , didnt have any seals or anything like it says on tr's website
Old Oct 3, 2008 | 10:11 PM
ae13291's Avatar
Great advice
what a deuce bag, at least be helpful yourself
Old Oct 3, 2008 | 10:21 PM
94'BLKBRD's Avatar
Ara pleaseeeeee learn how to spell you dumb ****!
It's douchebag
Old Oct 3, 2008 | 10:41 PM
ae13291's Avatar
^^ im to sophisticated <------ do u want to check the spelling on that smart ***. you would know how to spell douchebag probably since you use one
Old Oct 12, 2008 | 10:13 AM
neil1b's Avatar
Default coolant tube gaskets
Soooooooo........... does anyone know for sure if they are needed or not??????
Old Oct 12, 2008 | 11:18 AM
Mart00SS's Avatar
Couldnt say for sure, but if its not leaking after driving the car, I'd say that you are fine. The object is for it not to leak. Just drive it and check it every so often.
Old Oct 12, 2008 | 04:22 PM
bowtiee's Avatar
Just wondering...Im about to do this same swap on my LS6. Am i correct thinking I do not use the rear cross tubes and use the plugs to plug off the holes and only use the front cross over tube onle?
