Heads for the MS4
Our MS4 will work great with a set of PRC stage 1.0 LS6 cylinder heads if you do not want to fly-cut. If you want to fly-cut, I would go with the PRC stage 2.5 5.3 heads. The stage 2.5 5.3L heads made more HP (6 if I remember right) vs. the stage 1.0 LS6 heads. If you want to run the 5.3L heads, you could run our MS3 camshaft without fly-cutting the pistons. We can build the 5.3L heads to clear with our MS3 cam; just specify when you order.
No matter whether you go 5.3L or LS6 heads, you can get the heads, cam, and hardened pushrods for $1,684.99 or $1,819.99 with the dual spring kit, respectively.Feel free to give us a call, e-mail, or PM any of us with any questions or concerns. We'll be glad to answer any questions you may have.
FYI, look for a new stock bottom-end 346 heads/cam record at the LSX Shootout in Memphis. It will be with the MS4 and new PRC 215cc cylinder heads.
Trevor
Texas Speed & Performance
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
As always, on these max effort camshafts we recommend checking your ICL (degreeing the cam) to ensure the valve events are where they were intended to be. Camshafts can be a few degrees off, timing chains can be off too, etc. You add up a few of those little tolerances and can get in trouble quickly. That responsibility is always on the end user and his installer.
No, they post dyno numbers, but never put it on the dyno. They just add the advertised gains to the stock number, add 25% and call it drive wheel hp. Just like the guy with the 400whp civic who lost to my 130rwhp 85 V6 camaro. /end
