Re-camming my car
I haven't really kept up with what options are out there for the past year so give me some suggestions. Thanks
if not and just a weekend warrior and dont wanna put a huge 240 duration cam in you are not going to gain much from a the swap if you aleady have a 228/226...maybe 5-8 hp not worth it in my opinion, for all the time and money...would get better gains with a fast 92/92...and keeping the cam you got...
243 heads - ported w/ Patriot dual springs
Comp Cams 228/232 .600/.601 111LSA cam.
Cost is under $1600
But seriously. Keep your cam. Do the head work. At least a VJ. Once you can flow at 7500 RPM, THEN you can make some real power.
Lunati Voodoo 60512
232/238 .599/.601 113LSA
Nasty idle, doesnt slam the springs shut, makes a lot of under the curve power, and isnt that expensive. The 113LSA gives it a very unique sound. It seems to be right there in what you're looking for. While you;re at it, get a 2 piece timing cover from Edelbrock... It would take a considerable amount of time out of your next cam install... because none of us can have just one cam
