rotating assymbly
Old Oct 9, 2008 | 02:02 PM
TAP04's Avatar
Default rotating assymbly
about to start building a 408 stroker iron block, any opinions on a forged rotating assymbly???
Old Oct 9, 2008 | 02:10 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We've got quite a few available on our website. Are you going to be using any power adder? If so, which one and how much? What are your power goals? What heads/cam are you going to be running so that we can recommend the right piston to get your compression where it should be?
Let me know if I can help! We keep most all these components in stock and ready to ship. if you want us to balance the assembly, it typically only takes a few days from the time you order!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
