Head Help on a 370........
1. Stock 317s with a mild bowl job and good valve job milled .030...
2. 5.3 heads with a 2.00 intake valve with the bowl and runners mildly ported.
How far behind the the 317s are the 5.3 heads as far as flow? I think the compresson bump will help if the flow is close. Let me know what you guys would do. thanks...
I have 317 with TT Setup works awesome but for N/A and Nitrous I dont know if they work great for the setup.
While 2.04 would still fit it is counter productive (stock seats 2.02), so IMO 2.04 and bigger should have aftermarket seats.
BTW flow difference between 2.02 & 2.04 is like ~ 5 cfm +/-
5.3L unported are more restrictive than even LS1 castings, 6.0 castings are same as 243 LS6/2 castings but with bigger chambers.
5.3L shine only if fully ported, then you benefit of a small chamber as well.
Since you will have pistons with valve reliefs, you can mill the 317s as you like.
maybe .040, but then manifold aligment issues may arise.
using gm mls gaskets and arp head bolts or studs.
To answer your question I would need more info.
Cam specs at .006 lift
Bore size
stroke size
rod size
gasket thickness compressed
valve relief size
Piston hole position (piston deck height)
Max lift occurs at BDC and not TDC where contact with piston occurs (usualy within 15* BTDC or ATDC
