Anytips on removing the old headgasket stuck to the block?
Old Oct 12, 2008 | 03:47 PM
davered00ss's Avatar
Moderator
I used an ice scrapper. Just remember it's aluminum and will scratch easily, then not seal properly.
Old Oct 12, 2008 | 03:54 PM
vettenuts's Avatar
Bamboo chopstick filed to a scraper. Then nylon scotchbrite pad (no metal in it). I just finished mine a few minutes ago. To do it right and not risk the aluminum it takes time. I started mine yesterday morning (doing some other things in between).
Old Oct 12, 2008 | 06:02 PM
02 BLK WS6's Avatar
I got under a corner on my head gasket and peeled it off in one piece. I then used a wire wheel on a drill to clean the surface on the block and the head got resurfaced. I didn't pull the head b/c of the gasket. It was pulled b/c I burned a valve.
