Anytips on removing the old headgasket stuck to the block?
Old Oct 10, 2008 | 02:00 PM
scottHMT's Avatar
Default Anytips on removing the old headgasket stuck to the block?
Or should i just have at it with a razor blade? Looks to be stuck on there pretty good.
Old Oct 10, 2008 | 02:03 PM
conan's Avatar
Razor blade and I've used a green scoch pad. Just take your time and be gentle on the aluminum. You can use some brake cleaner too.
Old Oct 10, 2008 | 10:46 PM
Slo-Mo-Shun's Avatar
Air hammer and a chisel bit... j/k
Old Oct 10, 2008 | 10:48 PM
styoung's Avatar
maybe some gasket remover? i would only use that on a full teardown though.
Old Oct 10, 2008 | 11:48 PM
sroach20's Avatar
ice scraper
Old Oct 11, 2008 | 12:00 AM
snake charmer's Avatar
i used a razor blade on mine but be easy as the aluminum block can scar . some scotch pads , similar pads and abrasives contain aluminum oxide . gm has posted about the use of such will cause bearing damage and eventually engine failure .
Old Oct 11, 2008 | 02:49 PM
1bigcamdls6's Avatar
i used ice scraper and 1000 grit sandpaper...just enuf to remove old gasket...no probs after high revs and 2000miles
Old Oct 11, 2008 | 03:15 PM
Samba242's Avatar
Originally Posted by sroach20
ice scraper
Ditto that. I used the ice scraper for the broad strokes and VERY gently/carefully used a razor blade to get any residual material.
Old Oct 11, 2008 | 05:03 PM
bad6as's Avatar
i had this isses also. but mine was on the water pump gaskets. napa sells a gasket remover spray. makes things 100 times easier
Old Oct 11, 2008 | 05:07 PM
2000TransAmWS6's Avatar
ice scraper
Old Oct 11, 2008 | 09:03 PM
sroach20's Avatar
do you know if it works on the crap left over from the mls head gaskets?
Old Oct 11, 2008 | 11:28 PM
bad6as's Avatar
i dont know what the mls is. i think munit layer steel, but the gaskets to my water pump was the paper kind.
Old Oct 12, 2008 | 12:35 AM
00pooterSS's Avatar
Razorblade and water, go easy and take your time. Stuff the cylinders with rags if you want to help cleanup when your done, try not to get crap in the oil drain galleys, and definately flush the engine, as in when done with assembly leave the drain plug open on the pan pour a couple quarts through, just use cheap oil if you want,then also may want to change the oil early the first change.
That may be a little overboard but will be on the safe side.
Old Oct 12, 2008 | 12:46 AM
Damian's Avatar
LSX Mechanic
Razor blade? Yikes. Guess you guys aren't that busy and can spend 3 hrs removing head gasket material
To the orig. poster, if you don't have access to air and a die grinder, here's a ghetto way to do it. Get yourself (if you dont already have one) and decent battery powered drill. If you don't have one, WalMart sells a cheapo Black & Decker 7.2v for $19.99 that works great. Hit the tool store and buy a fine brush wheel. Something similar to this...
Make sure it's fine and not coarse. Stick it in your drill, and go over the surface of the deck applying medium pressure. The brush will do the rest for you. You can have an entire deck cleaned off in about 10 minutes with plenty of elbow grease left over
Once you're done go up and down all the cylinders wiping them down real good to get all the dust & residue out. I'd also stuff some rags down in the lifter valleys to make sure they stay clean. Also wouldn't hurt to bring each cylinder to TDC, take your wire brush, and clean all the carbon buildup off the pistons. This can only help power, not hurt it.
Old Oct 12, 2008 | 01:14 AM
m6camaro's Avatar
I used a fine bristle brass brush with just a little paint thinner on my iron block. Gasket pieces came right off without scratching the block at all. I am not sure about aluminum though.
Old Oct 12, 2008 | 03:04 AM
00pooterSS's Avatar
Those would be great if you dont mind the bristles breaking off and ending up in places you dont want them, if you have to buff them off use roloc discs thats what I always use at work.
Old Oct 12, 2008 | 03:14 AM
eallanboggs's Avatar
I like to use the single edge razor blades mounted in the handle made for this purpose. One other thing you can do is have a vacuum cleaner wand in your free hand as you scrape the debris off of the deck surface. This helps keep the small pieces of trash from finding their way down into the water jacket. Once you get the majority of it off use some scotch brite pads with some of the nasty solvent stuff that burns your hands where all the cuts you got while pulling the heads off are. Damn that stuff hurts. Don't take short cuts on this step. It is VERY important that the deck surface and face of the cylinder heads be clean enough to pass Sargent Carter's inspection. A little extra time and effort here pays big dividends down the road.
Old Oct 12, 2008 | 09:45 AM
01ssreda4's Avatar
i use the surface prep roloc discs on my die grinder. it was a cast block though
Old Oct 12, 2008 | 03:37 PM
guys im telling u either 1000 or 1500 grit sandpaper u can get it pretty much anywhere and dont have to worry about it screwin up ur block it doesnt take enuf off to do that...although my deck looked chrome when i was finished not sure how good that is...anyway have had no probs yet
Old Oct 12, 2008 | 03:43 PM
00pooterSS's Avatar
Thats also fine.
