L76 T56 Pilot bearing part no.
I have just learnt the long way around I need one of the pilot bearings that seats in the smaller diameter recess deeper in the crankshaft.
The local bearing bloke cant find a generic SKF, NSK etc etc part number and I was hoping someone could help us out.
6902 bearings are 28mm OD and 15mm ID and all but fit, but they dont. I was planning to use two of them in there.
Failing the lack of an available cross reference I'd also be happy with a part number that our local Holden dealer can obtain. (Happier but lighter in the pocket)
Thanks for any help.
A sponsor sells them:-
http://www.ws6project.com/user_stor/...oducts_id=1209
Hope this helps.
I brought one of these and found it came with the clutch kit, but not sure what I done with it, if I knew where I'd put it i would have sent it on to you.
Hope this helps.
Thanks Red, and for the offer.
Local Holden dealer does a bronze bush for $55.50 so for now I settled on same from the local Auto Pro store for circa $6.00 as I need it now(ish).
I will however look into ordering a cpl of rollers, 1 for a spare even.
Thanks for the heads up.
