Trick Flow heads ?????'s
Old Oct 31, 2008 | 04:50 PM
sublime1996525's Avatar
Default Trick Flow heads ?????'s
I have an 02 Z06 and I just bought a pair of tf 215cc heads that have been milled down to 59cc. That puts the compression ratio at 11.48. Am I going to be able to run 91 octane gas with this set up? I'm planning going with a mid 230's duration cam. Any help or opinions would be much appretiated!
Old Oct 31, 2008 | 05:07 PM
odarabla's Avatar
Yes you can run regular 91 octane pump gas with 11.4:1 comression with no worries.
Old Oct 31, 2008 | 05:29 PM
Oops, I just realized I posted this in the gen IV section, supposed to be in the gen III. My bad.
Thanks, I feel a bit better know!
Old Oct 31, 2008 | 05:44 PM
ATLSS's Avatar
+1....
Old Oct 31, 2008 | 05:57 PM
ringram's Avatar
Depends on your cam timing really!
Old Oct 31, 2008 | 07:02 PM
Grimes's Avatar
Yeah, octane needs really depend on cam, design of heads, and other factors, but I think the general consensus is that you will be fine.
Old Oct 31, 2008 | 07:57 PM
massls1guy's Avatar
Best thing to do is read up on dynamic compression ratio (DCR):
https://ls1tech.com/forums/showthrea...dcr+calculator
You can enter your cam, chamber volume, head gasket thickness, etc. in the spreadsheet. Then adjust your variables so DCR is at or under 8.5 to avoid detonation on pump gas.
Old Nov 1, 2008 | 02:01 PM
Sweet thanks guys!
Old Nov 1, 2008 | 02:36 PM
Wow talk about teattering on the threashold. I'm at a DCR of 8.44 or 8.5 depending on head gasket thickness. Unless I go with a bigger cam then I'm in the 8.20's range but I don't want to sacrife too much driveability. Unless I go with the lunati (232/238-599/601 113lsa) then I'm about 8.32. What do you guys think?
Old Nov 1, 2008 | 05:51 PM
SSPerformance's Avatar
why not just run 93 in the car. your talking 5cent a gallon diff not huge.... not worth the risk in my opion. Now it all depends on your tune how good it is and how much timing is in it... its all in the timing
Old Nov 1, 2008 | 06:22 PM
massls1guy's Avatar
Well you have a high quality set of heads there, I'll bet you will get good numbers either way. I would go with the smaller cam with higher DCR myself.
Old Nov 1, 2008 | 07:00 PM
I'm in California and there are no places around here that I know of that have 93 octane.
Old Nov 1, 2008 | 07:06 PM
o ok now i c. Its all in the tune.....
Old Nov 4, 2008 | 11:33 AM
So as long as I find a good tuner hopefully all will be well!
Old Nov 4, 2008 | 01:09 PM
Clevite Kid's Avatar
With a tight quench (or "squish") dimension, like 0.030" or less, the design of the heads for LS engines, along with the properties of aluminum heads, lets us run at dynamic compression ratios of 8.7 to 1 on 93 octane. You could probably run 91 octane on the same setup by pulling back on the timing a little at WOT.
Old Nov 4, 2008 | 05:38 PM
With a comp thickness of .054 I'm sitting at an 8.46 dcr which is right about where I want to be. Right?
Old Nov 4, 2008 | 06:00 PM
Ok I have one more question. Am I going to have any PTV issues with this setup running a 232/234-595/598 112lsa cam?
Old Nov 6, 2008 | 06:08 PM
odarabla's Avatar
Ok I have one more question. Am I going to have any PTV issues with this setup running a 232/242-595/598 112lsa cam?
Why so big on the exhuast? Check out the video in my sig. Thats with the same heads you have a 232/236-646/612@114LSA cam.. No N2o and a full weight 3600lb Camaro with stock bottom end motor. Oh. back to your question. You shouldn't have PTV issues with that cam and the trick flow head. It's built @ 13 degree valve angle.. Again No Worries!!
Old Nov 7, 2008 | 09:46 AM
That's supposed to be 232/234. I didn't think I'd have any issues but I'm just trying to cover every base.
