Map sensor on l-76 manifold
Old Nov 3, 2008 | 10:48 AM
1lejohn's Avatar
Default Map sensor on l-76 manifold
I was wondering how people were mounting the map sensor on this manifold. I guess just drill a hole and glue it in. Any thing is got to be better then the fast design. Also on the valley cover for a L-92 block what is the the threaded hole on the rear of the cover for. Is it for the oil pressure sending unit?
Old Nov 3, 2008 | 02:45 PM
sroach20's Avatar
you mount the map sensor on the front near the tb, not the rear like the ls6/ls1 intakes.
Old Nov 3, 2008 | 09:23 PM
1lejohn's Avatar
Thanks. I found a picture of it. The oil sensor screws into the valley plate.
