Fiber Tuned Flow Bench Test Results
Old Nov 20, 2008 | 09:19 PM
nmass399's Avatar
looks pretty descent, nice to see others comin out with manifolds to use, looks like it flows well and looks cool too
Old Nov 21, 2008 | 10:26 AM
Big Bird WS6's Avatar
so where do i put my vacume line? and my map sensor line?
Old Nov 21, 2008 | 11:18 AM
860 Performance's Avatar
There are 3 npt's in the fron and 3 npt's in the back
Front
Evap
Front mount MAP
PCV
Rear
Brake booster
HVAC
Rear mount MAP
Old Nov 21, 2008 | 02:45 PM
^^^ and the ones i don't nee. just block or what? can you post pics of these npt's if they look shitty it will break me from buying one. or can i order it with just the ones i want.
and sorry what is Evap? or HVAC
Old Nov 21, 2008 | 03:06 PM
Take a look at post# 106 here:
https://ls1tech.com/forums/generatio...anafold-6.html
or if you want custom holes, just let me or Dave know. Since we make them 1 at a time, I'd be happy to add or delete any holes you want.
Old Nov 21, 2008 | 11:33 PM
thank you. i will get in touch. i want one. just might have to call you and talk about it first
Old Nov 22, 2008 | 10:02 PM
jwarren's Avatar
Front
Evap
Front mount MAP
PCV
Rear
Brake booster
HVAC
Rear mount MAP
Do you (or can you) provide the the fittings needed to connect these items? I realize not everyone will need them but it sure beats having to track them down.
Old Nov 23, 2008 | 08:16 AM
All the fittings are included.
Old Nov 30, 2008 | 03:48 PM
405HP_Z06's Avatar
What are the runner dimensions at the head for cathedral and rectangular port versions? Do you have any flow data for the cathedral port versions? What is the runner cross sectional area at the inlet in the plenum?
I assume one can use any LSx compatible fuel rail?
Old Nov 30, 2008 | 05:50 PM
The ports line up to stock heads, but can be ported to match any.
Richard will be flowing the cathedral next. I'm sure he will share his results.
Aftermarket LS fuel rails work. I've been buying them from Speed Inc. so I'm sure those fit.
Old Dec 3, 2008 | 10:18 AM
Very Wild Bill's Avatar
Nice numbers.
Thanks for the information.
Old Dec 29, 2008 | 11:20 PM
  #32
skyhighsami's Avatar
no title here
I would like to know if you plumbed it for a direct port set up how the runners would take the N2O if it would be an issue at all and what the power range of this is
Old Dec 30, 2008 | 01:11 AM
  #33
1BADAIR's Avatar
has any testing been done with a wet kit? I am wondering if it will have lean cylinders
Old Dec 30, 2008 | 07:03 AM
  #34
98Z28CobraKiller's Avatar
Restricted User
We have one (cathedral port) on order with a direct port wet kit pre-plumbed. We should have some info on that by mid January.
Old Dec 30, 2008 | 08:26 AM
  #35
Frans96SS's Avatar
I need 2 LS7 ones.... Please start making them.
Old Dec 30, 2008 | 11:21 AM
  #36
Old Jan 1, 2009 | 06:35 AM
  #37
no title here
How much for that?
Old Jan 30, 2009 | 11:05 PM
  #38
Slow77ta's Avatar
Any thoughts of an LS7 intake and could it clear the firewall, and hood? I am sure there would be a market for it, not huge but you could sell them. If you only have to design the composite pices maybe that could work out to be cost effective for you'll to look at doing.
Old Mar 18, 2010 | 02:59 PM
  #39
Gregory's Avatar
Does anyone know if this Fiber-Tuned intake manifold is still made?
I have telephoned and e-mailed the company to no avail.
Old Mar 18, 2010 | 03:31 PM
  #40
Stang's Bane's Avatar
Another example of flow bench results not being the final word in testing.
