Intake setup for L92's..thoughts..
Old Feb 24, 2009 | 11:19 AM
94 guy's Avatar
dlove what lenght water pump belt are you running?
Old Feb 24, 2009 | 02:26 PM
00Formula00's Avatar
Originally Posted by dlove
Dan is right, I actually slowed down with the GMPP. Probably a cam issue. I even spun it 7300+ and it still wasn't as fast.
I ported my L76 intake this time and it pulls much better up top. I plan on doing the FAST intake/tb setup once it comes out.
The L76 unported choked up the car pretty bad above 6400
Who did the porting?
Old Feb 24, 2009 | 02:47 PM
dlove's Avatar
have no idea. can't remember
I do all my own work
Old Feb 24, 2009 | 02:52 PM
Do you do work for other people? haha
Old Feb 24, 2009 | 03:19 PM
ItsNotStock's Avatar
The whole myth about the L76 petering out at 6,000rpm is a lie. I have seen a dyno graph on an unported one still gaining to 7,000. I personally switched from the L76 to a GMMP single with a sheet-metal elbow, but I'm going with FI. N/A I see no reason to switch.
There is a reason you don't see aftermarket (plastic) intakes for these heads after years and years. Companies haven't been able to make any gains over the stock one. But it seems Fast finally cracked the code-Although I wouldn't hold my breath on that one either. If it's 10hp I wouldn't waste $1,000 on it.
Old Feb 24, 2009 | 11:04 PM
dlove's Avatar
sorry buddy. Im sure some of the sponsors would be glad to help though
Old Feb 25, 2009 | 10:54 AM
ssinister550's Avatar
Originally Posted by WizeAss
Fabricated elbow in my sig.... and a 236/248 cam with a TH400/9 inch setup.28 degrees of timing.
thats a mean lookin dyno sheet man, it looks like it wants to keep making power have you ever spun it higher?
Old Feb 27, 2009 | 03:48 PM
Jordan81's Avatar
whats the difference, if any, between the GM l92 cast intake compared to the vic jr. from edelbrock?
Old Mar 1, 2009 | 12:32 PM
Texas_WS6's Avatar
I am running that elbow with my GMPP carb EFI manifold. When we flowed the heads, manifold, and elbow, I can tell you the elbow made no negative efect on the flow bench. It seams to be a very good peice at this time.
