putting 92MM TB on 90MM mani
Old Dec 14, 2008 | 06:34 PM
1meantransam's Avatar
Default putting 92MM TB on 90MM mani
what would i have to do to get the 92 MM Nick williams TB to work on my 90MM L76 manifold? i know it's pretty much the same but will i have to shave the mani a little or will it be fine bolting right up?
Old Dec 16, 2008 | 04:37 PM
Nick Williams's Avatar
It will work just fine. The mis-match will be minimal since the l76 intakes measured were 91.xx mm. You can always port the intake a little to match if you want to.
Nick
Old Dec 18, 2008 | 07:42 PM
PowerShift408's Avatar
My throttle body is advertised as a 91mm, got it from New Era Performance. If anything, just do a bit of porting if it doesn't look flush to you.
Old Dec 22, 2008 | 09:31 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We sell the PTM 92mm throttle body for installing on the 90mm intakes all the time. They work great & they're a great buy!!
$349.99 on special!!
http://www.texas-speed.com/shop/item...d=891&catid=73
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
