Fiber Tuned Intake Review with pictures
Old 02-21-2009, 11:47 AM
  #321
ChevPower's Avatar
Originally Posted by 98Z28CobraKiller
Whoops, thanks for the correction. Regardless, those monster heads should and will be run with 2" primaries.
I just read a few pages back that the test was being done on out of the box afr's Whats so monster about them? So they test where on TFS heads? or AFR's?
Old 02-21-2009, 11:55 AM
  #322
speedracer5532's Avatar
Here are the results plotted with power and torque.
I know I won't be getting rid of my FAST anytime soon, unless magically the fiber tuned does alot better in a forced induction application.
Old 02-21-2009, 12:25 PM
  #323
miami993c297's Avatar
http://img.photobucket.com/albums/v2.../fiberdyno.jpg
Hi speedracer5532,
Thank you for the clear graph, numbers are never lying, and magic is for fairy taile...
Christian
Old 02-21-2009, 01:17 PM
  #324
silverbeast's Avatar
Thanks for the honest results guys. I have a GMPP intake that has one hell of a port job done to it so i am excited to see how it does.
Old 02-21-2009, 02:02 PM
  #325
ls2formula's Avatar
TFS 245's. It was gonna be done on a different motor before but we thought this would be a better test mule.
Old 02-21-2009, 03:15 PM
  #326
Restricted User
98Z28CobraKiller's Avatar
Yeah, we ended up using the the 422 LSX w/ solid roller TFS 245's. I thought I posted that a week or so ago.
Old 02-21-2009, 05:51 PM
  #327
Originally Posted by miami993c297
Hi speedracer5532,
Christian
I know numbers never lie and magic is for fairy tail....what I meant was I expect similar results as these even in forced induction....the FAST will be better up until about 6500 rpms then the Fiber Tuned will prevail.
Old 02-21-2009, 09:58 PM
  #328
Restricted User
I don't think so. With forced induction the intake will flow more similar to how it flows on the top end. The more air you ask it to provide, the better, I suspect, it will perform,
Old 02-22-2009, 09:52 PM
  #329
MPM IV's Avatar
Thanks for sharing the results.
Old 02-24-2009, 11:46 AM
  #330
Flow Wizard
Tony Mamo @ AFR's Avatar
Good stuff...
The graph tells the story fairly well.
Looks like the Fibre-tuned could still use a slightly longer runner IMO but all of this type of stuff just takes a tremendous amount of dyno time and R&D (barring getting lucky quickly!)
A high strung aggressive solid roller motor spinning 6200-8000 RPM would certainly benefit from the current design but it wouldn't makes sense for the garden variety hyd. roller combinations that are alot more prevalent here.
-Tony
Old 02-24-2009, 12:10 PM
  #331
Race your car!
JL ws-6's Avatar
From the looks of that graph, maybe a 440 ci solid roller motor that will see 8500 might work well with it, but I would be willing to bet you take this intake, put it next to a port matched single plane like Cary's (both being about the same price) and I would hedge my bets on that single plane making more power, and the under the curve area again, would probably have similar results to what has already been found.
Old 02-24-2009, 12:25 PM
  #332
Restricted User
But Cary's intake wont fit under the hood.
Originally Posted by Tony Mamo @ AFR
Good stuff...
-Tony
I gotta call you about fixing my heads.
Old 02-24-2009, 02:12 PM
  #333
Race your car!
JL ws-6's Avatar
Might be right, but then again anyone putting a 440 CI 15 to 1 compression 9000 rpm motor in a car that needs this kind of intake flow up top probably doesn't mind doing some trimming to make it work.
Hell that's all probably cut out in the attempt to get the raceweight down anyway, so that's a mute point.
Old 02-24-2009, 04:43 PM
  #334
3fingas's Avatar
Heheheheee
Old 02-25-2009, 10:37 PM
  #335
"All Motor 9 Second club member"
TXCAMSS's Avatar
I just stumbled onto the is thread. It's a long winded one, but worthy of attention no doubt.
I'd love to see a good proven FAST intake alternativeas well.
FWIW we started off shifting at 6800rpm and bumped the shift points up to 7200rpm to lower the trap rpm down to 7400rpm. Our MAP on the old 408 was 99-100 at WOT. Now with the 445 and the same FAST 90mm intake the MAP readings are 93-94kpa. I'm taking that as an indication of a restricted manifold for the engine size or volume of air movement needed?
Old 02-26-2009, 01:52 AM
  #336
Hmmm. I would like to see your car ( TXCAMSS) give this intake a try and see what happens at the track.
Old 02-27-2009, 06:54 PM
  #337
Restricted User
Well I sent our other one back today to have the partition removed for my boosted build. We will see. My friend with the solid roller (test bed) is going to restall for this intake and give it a chance to work up top. Track times for the big spray high RPM motor and for my boosted build will be coming within the next month or so.
Update: Hope to have the boost reinforced intake back by the end of next week. Turbo build is coming along pretty quickly.
https://ls1tech.com/forums/forced-in...ld-w-pics.html
The Fibertuned Intake and solid roller LSX that were test on the engine dyno are in the car now and we hope to have some track times next Friday. Here's a picture of that one almost wrapped up.
Old 03-12-2009, 05:13 PM
  #338
GIGAPUNK's Avatar
Well if nothin else, it looks great! How high are you going to spin this one? And which runners are being used this time?
Old 03-12-2009, 07:48 PM
  #339
Restricted User
8,000 RPM with the short runners on the solid roller setup. This is LS2Formula's ride. Mine will be boosted and I will try to shift at or before 7K RPM also with the short runner.
Just got mine back today reinforced for boost. Looks great Vinny! I'll get some pictures once I get it in the car and get the turbo plumbing hooked up.
Old 04-30-2009, 09:26 PM
  #340
MelScrilla's Avatar
so is the boost better then the n2o
Quick Reply: Fiber Tuned Intake Review with pictures
