GMPP engine controller on L92
Thanks
I have not looked at the L92 truck intake on the shelf so I don't know about the throttle body or map sensor connections.
As the person above stated you can tune the parametes with tuning software.
I use the HP Tuners to tune mine.
What intake do you want to run?
Robin
Thanks for the info about the cam. The engine would never see over 5000 rpm, so probably it would be OK in the advanced position. At about 3000 to 5000 rpm do you see much decrease in power with the cam advanced?
Robin
I don't know the program on the cam for L92 so I can't say when they retard the it. Comp is working on a controller to run the phaser in non phaser equiped applications.
Mast Motorsports had developed a controller and cam for the L92 engines. At one point they would only sell them as crate engines. Check with Mast, maybe I am wrong or that might have changed.
All the long block sensors are the same. The 5 wire on the cam harness splits to 3 for the cam sensor and 2 for the phaser. Remove the harness and plug the cam sensor wire to the cam sensor. Remember that the OEM harness "flips" the wires from the lug to the sensor. You should be able to re pin for that.
Robin
Robin
Im running an LS7 harness on an LY6 with an L76 intake and everything snaps up. What front accessories are you running? If its the car stuff, I would definitely put on an LS3 or L76 intake while your swapping stuff.
They just make a little blocker to stop the phaser moving more than 20* max. Or you can leave it out and just keep to under 20* unless you feel like punching pistons.
You will also need an LS2/LS7/L76 fuel rail.
The throttle body will bolt right on.
The LS3 and L76 MAP sensors not only have a different mounting interface and connector, but also a different calibration(or transfer function). We can run either one.
Our M-90 Control Packages and M-90 Performance Packages are available separate from our crate engines.
Hope this helps!
From the dyno charts I've found comparing the VVT enabled and disabled, I can't see a lot of difference until close to 5000rpm. If that's the case, the VVT won't do anything for me, since the engine will never see over 5000 anyway. If that proves correct, I'll leave the VVT in place, run it in the default position, and ignore it. I want the best power I can get in the 3000 to 4800 rpm band and I couldn't care less about anything above that.
The truck intake is very close to having clearance issues, but I won't know until I get home to measure the actual height and see if there are any bosses or bumps that can be ground off if necessary. I hope I can use it, but if not, then the LS3 intake will be necessary.
I do plan to use the stock truck alternator mounting and serpentine setup, without the power steering. Has anybody done this? I assume an idler will be needed to replace the PS, but I'm not aware of any being sold for that.
