ati super damper install gto
Old Jan 6, 2009 | 09:29 PM
McNair06Goat's Avatar
Default ati super damper install gto
need help on how to install a ati hub on a callies crank on a ls2 cant get on far enough to get the bolt on. any help from you guys would be great.
Old Jan 7, 2009 | 03:49 PM
stcloudguy's Avatar
I would go to your local fastener supplier and by a piece of threaded rod and a nut with a couple of washers, pull it on with that until your bolt will reach.
Old Jan 7, 2009 | 07:35 PM
SweetS10V8's Avatar
16 x 2.0
Old Jan 7, 2009 | 08:17 PM
860 Performance's Avatar
I had the same problem, ended up modifing an install tool to pull it in.
