Will L92 heads work on a 2002 LQ4?
Honestly just plan to check it. Think ahead to 5 seconds before you start the engine back up, your going to be wondering if you should have really checked your PTV or not...How much is your gamble going to cost you if there is PTV clearance issues(time and money)? Versus taking an hour or so and checking PTV clearance and KNOWING.
Who knows the cam could be ground incorrectly, or the cam could get installed on the wrong centerline. If your not checking PTV I can be fairly sure your not degreeing in your cam either. Remember, these vavles are huge @ 2.16".
Also remember that L92s on a LQ4 shortblock will give you a compression ratio of about 9.15:1. I actually cc'd the reliefs in an LQ4 and calculated the compression of it with L92 heads once. Its going to be low compression.
Guys thanks for the replies. So a LQ4 with L92s would be great with a turbo with that low compression.
